Peanut Port 454 build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-01-2013, 12:35 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
WHERE is the accounting for the parts to make EFI systems tick??.
  #17 (permalink)
Old 10-01-2013, 12:57 PM
stock bbc fuel injection system, a performance oriented computer plug and play. So you can add bigger cam headers and compression. Gm performance has everything to build this high torque performance engine. I hope this helps answer your question.
  #18 (permalink)
Old 10-01-2013, 02:37 PM
1Gary's Avatar
Originally Posted by arless View Post
stock bbc fuel injection system,"a performance oriented computer plug and play".
Don't be so quick to dial up that EFI number.$$$$$$
  #19 (permalink)
Old 10-01-2013, 02:40 PM
Originally Posted by 1Gary View Post
I looked that the "other" thread and let it go.Now this thread too??.
LOOK THESE "COMIC" BOOKS LIKE CAR CRAFT AND ALIKE HAVE A VESTED INTEREST IN HAVING DYNO RESULTS THEY DO IN THEIR FUDGED ARTICLES!!
If anything of value come from them is a knowledge of how to read between the lines.Even at that,there is sooooooo much B.S. in the articles,you best off taking to heart the advise given on here.
True thats why I want to build a performance package that would yeald 500 hp with 9.4:1 compression then take 12% of the horsepower by taking a way two points from the compression down to 7.5:1 would yeald 440 horsepower. Plenty for a street motor. 87 octane fuel, no stress on parts. The motor would last forever. With mobil 1 sinthectic 5 w 30.
  #20 (permalink)
Old 10-01-2013, 02:45 PM
vinniekq2's Avatar
If compression level gets too low,you may not get a good fuel burn
  #21 (permalink)
Old 10-01-2013, 02:47 PM
maybe a good msd kit will help
  #22 (permalink)
Old 10-01-2013, 03:09 PM
Most EFI systems i've seen, help dial up torque in the low and mid rpm, better milage--- start up cold and drive off. nothing can replace a Holley carb for high mid rpm to high rpm.
  #23 (permalink)
Old 10-01-2013, 10:43 PM
1Gary's Avatar
That's not how it works.It's hopeless.Ya can only teach the willing.
The Following User Says Thank You to 1Gary For This Useful Post:
vinniekq2 (10-02-2013)
  #24 (permalink)
Old 10-01-2013, 11:47 PM
OK mr. know it all how does it work
  #25 (permalink)
Old 10-02-2013, 11:37 AM
RWENUTS's Avatar
At least he's entertaining!
  #26 (permalink)
Old 10-02-2013, 12:57 PM
techinspector1's Avatar
Wiki Edits: 326
Arless, you'd be a whole lot more credible if you were asking intelligent questions instead of relating magazine builds to us. You may not have been there and done that, but we have.
  #27 (permalink)
Old 10-02-2013, 08:13 PM
I can do that
  #28 (permalink)
Old 10-02-2013, 08:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I am familiar w/that CC article about the $2,650 big block Chevy. And I have built a 454/468 BBC that used c/n 236 peanut heads that I ported (~220cc avg. intake volume). So I know from first hand experience that the numbers represented in that particular CC article are not fudged any more than whatever correction factor that may have been used.
Bottom line: Peak numbers of 446 hp at 4,900 rpm and 542 ft/lb torque at 3,600 rpm from a 9.4:1 454 BBC is not even close to being unrealistic using the XE268 cam and other parts they used.
  #29 (permalink)
Old 10-02-2013, 09:30 PM
I love an article that gets a lot of power and torque from really cheap parts. That big motor would last a lifetime with less than 5000 rpm for max power. 3000 lb car or truck with an overdrive th 400 and 330 gears. Just the way I like a street everyday driving engine.
  #30 (permalink)
Old 10-02-2013, 09:35 PM
jokerZ71's Avatar
Wrench Turner
Arless's 440 HP 454 is gonna have 7.5:1 CR.
The Following 2 Users Say Thank You to jokerZ71 For This Useful Post:
1Gary (10-02-2013), vinniekq2 (10-02-2013)
454 Build 48bill Engine 7 04-26-2011 05:53 AM
454 Build black66 Engine 2 07-23-2005 12:41 PM
How can I build a 454 "POWER" Engine? stevecollins Engine 3 08-07-2004 08:55 PM
Want to build 500 horse chev 454 79monte Engine 6 05-29-2002 10:20 PM
