Pedal Assembly for the '66! - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Pedal Assembly for the '66!
Stock 0 0%
Wilwood Firewall mount 1 100.00%
Tilton Firewall mount 0 0%
Tilton Floor mount Steel w/accelerator pedal 0 0%
Tilton Floor mount Aluminum w/accelerator pedal 0 0%
Voters: 1. You may not vote on this poll
Old 03-27-2007, 10:01 AM
Last journal entry: '66 Chevy II Nova
OK...not sure if this is the right forum for this and moderator, please, if this isn't the right forum please feel free to move it wherever it should be. I need to figure out what kind of pedal assembly I should use for the '66 project I have going on!(ZO66) so here is a picture of each of the candidates. If anyone can offer up a better solution or can tell me why any one of these is NOT a good choice please feel free to post:
Stock:
(Hope it's OK to use your photo Bill!)
Wilwood:
Wilwood doesn't make an accelerator pedal that matches their Brake/Clutch set!
Tilton:
Firewall mounted -
About the same cost as the Wilwood!
Floor Mounted -
600 series -
All steel pedals w/ matching accelerator pedal and more than double the cost of the Wilwood!
900 series -
All Aluminum pedals w/ matching accelerator pedal and about 10 times the cost of the Wilwood!
I'm pretty sure as to which one I'm going to choose but I wanted to run this by the board and get some other opinions!
John
Old 03-30-2007, 12:08 AM
Damn! Only one persons got the cajones to vote???!!??
John
Old 03-30-2007, 07:38 AM
Due to lack of interest ...
And the fact that this is a POLL ...
Plus you have already stated you had made your mind up ...
I am sending this to the lounge ...
Deuce ... Moderator
Old 03-30-2007, 08:00 AM
OK thanks!
Old 03-30-2007, 08:31 AM
Last journal entry: car is painted
I would go with the Tilton. They actually engineer their products and constantly improve them.
Old 03-30-2007, 07:04 PM
Yeah but which one???
Old 04-04-2007, 11:49 PM
Damn! No one has the cojones to even vote for what they like or dislike?
John
Old 04-05-2007, 08:34 AM
It's hard for someone to tell you which pedal assy will work best in YOUR car. Go to your car and see which will be easier to mount. One thing, pedals with the pivot on the bottom feel different. Try driving a VW Bug.
Old 04-05-2007, 01:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What we like should not be an issue....build it like YOU want it.
Old 04-05-2007, 04:36 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Maybe people arent voting cause the poll is closed
Mike
Old 04-05-2007, 08:45 PM
OH? I didn't notice that! I have driven a VW before so floor mount doesn't bother me.
66 Impala turn signal switch assembly black66 Electrical 5 12-10-2010 05:07 PM
Brake pedal assembly help APalusky Suspension - Brakes - Steering 7 12-05-2006 05:09 PM
Clutch pedal assembly for flathead Lee Hulick Transmission - Rearend 6 04-02-2005 09:11 PM
Anybody have Lokar throttle pedal assembly shockers69 General Rodding Tech 3 02-09-2004 02:10 PM
Suggestions on a brake/clutch pedal assembly AHotRod Suspension - Brakes - Steering 5 04-02-2002 02:15 PM
