Pedal Boxes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2013, 09:33 AM
S10xGN's Avatar
Gotta love a turbo!
Pedal Boxes?
Hi All,
Has anyone used a floor-mount pedal box like this Wilwood?
My little Rambler American will have limited room in the footwell after enlarging the trans tunnel for a scattershield. I have a set of factory manual hanging pedals but they will require lots of mods to fit and it will leave me little room for a throttle pedal. My concern is my size 12's mashing all three pedals at the same time...
TIA!
Russ
Old 09-20-2013, 01:03 PM
Do you remember the old Ansen Hyd clutch and brake pedal boxes? They might work for you; if you can find one
Old 09-20-2013, 03:21 PM
junior stocker's Avatar
Those are being reproduced, and marketed on E-Bay; probably cost less that a used original. The dual chamber master cylinder would seem to be the harder to find part. Butch/junior stocker.
Old 09-21-2013, 08:40 AM
S10xGN's Avatar
Gotta love a turbo!
Not sure I can mod my factory pedals (move them towards the door) enough. If that's the case, hanging pedals are out and I'll need a floor-mount like the Wilwood. My concern is the proximity of the pedals to the others and having enough room for my feet to function...
Russ
Old 09-23-2013, 08:09 AM
We'll just call you 'Barefoot Bob'
Old 09-23-2013, 09:32 AM
1971BB427's Avatar
Why not relocate the factory pedals by either bending the arms, or cutting and welding them with an offset? I've done this on several swaps, and it works great. Just keep in mind if you bend them too much to one side it will change the ratio slightly, so sometimes cutting and extending them to get a "dogleg" in them works better. Arms don't have to be straight to work well.
I have a lot of engine setback in my Falcon with a BBC installed, so I totally lost all the original gas pedal room. I heated and bent both brake and clutch pedals, and made room for my homemade gas pedal. I still had to rework my freshly built trans tunnel with a small indent for the pedal area, as I needed room for the pivot for the gas pedal. As you might notice in this picture, the Falcon has a huge tunnel, but with pedals bent to the left I have room for the gas pedal, and no issues hitting two pedals at once.
Old 09-23-2013, 09:41 AM
techinspector1's Avatar
Wiki Edits: 326
Invest in a pair of driving shoes. Seriously.
The Following User Says Thank You to techinspector1 For This Useful Post:
AutoGear (09-23-2013)
Old 09-23-2013, 10:55 AM
**Note** "Barefoot Bob" is homage to the best dirt track driver of all time Bob McCreadie, from Watertown NY. His son Tim is a great driver in his own right; and had a development deal with RCR, and won the Chili Bowl
Old 09-24-2013, 09:18 AM
S10xGN's Avatar
Gotta love a turbo!
Seems you've been around awhile, have you tried one of these pedal boxes?
Gonna post some pix so ya'll can see what I'm up against. The steering column will also have to be moved as the throttle pedal will need to be where it is now. The pedal hanger is directly above the column and the pedals straddle it. Can't see any way to remove the hanger without compromising it's integrity and any the bends/hacks to the pedals will be severe to say the least. I could leave the scattershield in the engine compartment and just cut for the trans, but that would add extra weight to the front not to mention possible radiator interference. All are options...
Russ
ID:	83513   Click image for larger version
ID:	83521   Click image for larger version
ID:	83529   Click image for larger version
ID:	83537   Click image for larger version
Old 09-24-2013, 12:16 PM
Russ;
What is this car/truck? I forget what you're working on.
I like your idea but I worry about the height of the floor mount box. What about a Hydraboost setup, it might help unclutter things a little on the firewall
Does the floor mount system put the resivoirs under the floor?
Old 09-25-2013, 09:30 AM
S10xGN's Avatar
Gotta love a turbo!
Nate, it's a '63 Rambler American. If I didn't already have the gearbox/clutch/etc, it would be soooo much easier to just stick an auto in there and be done with it. This is the 2nd generation of Americans (61 - 63), the 1st gen (58 - 60) had under-floor pedals, so that "retrofit" is another option to explore. After closer inspection, I don't think moving the pedal hanger will work as it will push the master cylinder into the fender. The Wilwood box masters are all right behind the base of their respective pedals and the whole assembly could be cut into the floor slope, there's nothing behind it but empty wheelwell space.
Russ
Old 09-25-2013, 09:35 AM
1971BB427's Avatar
I still don't see any reason not to bend, or cut and offset the pedals to the left, using the existing pedals? Seems like it would not only be easier, but a lot cheaper, and will keep the master and clutch linkage in the same location they are now, but make room for the gas pedal.
Old 09-25-2013, 09:48 AM
S10xGN's Avatar
Gotta love a turbo!
That's definitely an option, but they'd have to be moved left around 6". I'll prolly try that first, but am not sure how much stress that will put on the offset cuts/welds/bends. Maybe more than I'd feel comfortable with...
Russ
Old 09-26-2013, 11:29 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I haven't used Wilwood floor pedals, but it sounds to me like that will be your best bet. After all, there is plenty room in the fenderwell to push into. For a street car I'd want to make a dirt shield to protect the master cylinders under the fender, not really necessary for a drag car. I guess this is a manual shift car, not automatic, since you mentioned "all three pedals".
Old 09-26-2013, 12:24 PM
In farna we trust
Relationship between Gas Pedal and Brake Pedal 35WINDOW General Rodding Tech 12 01-11-2012 01:35 PM
rocker boxes w.roger lafontaine Body - Exterior 11 03-10-2008 01:59 PM
speaker boxes 71 c-10 Electrical 14 02-16-2004 02:57 PM
speaker boxes 71 c-10 Interior 7 12-10-2003 02:50 PM
For those of you with full PM boxes.... Kevin45 Hotrodders' Lounge 5 11-11-2003 10:56 AM
