Pedal Goes to Floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2005, 07:58 PM
Pedal Goes to Floor
My daily driver is a honda accord. Today driving home from work my pedal started going to the floor. The first time I touch it it goes to the floor and if I keep on touching it it gets stronger. Just the first time after a block or so, that I touch the pedal it goes to the floor. This is weird because I didn't touch anything. Any ideas on what this might be?
Old 09-07-2005, 08:02 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I am assuming you are referring to brake pedal. My gas pedal is usually always to the floor. Is the master cylinder low on fluid? You may have a small leak in a line. If it is not leaking I would say your master cylinder is kaput.
Old 09-07-2005, 08:10 PM
Master cylinder is full and there are no signs of leaks.
Old 09-07-2005, 08:17 PM
poncho62's Avatar
Wiki Edits: 5
master cylinder................leaking internally past the seals.
Old 09-07-2005, 08:23 PM
dh79's Avatar
I agree.
My truck had a similar problem. It would stop fine, but the pedal would slowly creep down if you held your foot on it. This was particularly annoying at a red light on a hill. As poncho said, it's leaking past the seals internally.
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 09-07-2005, 09:53 PM
Wiki Edits: 31
Brothers '84 VW rabbit did the same except worse, was a bad MC. they had to be double pumped b4 they worked. Somehow it passed NY inspection like that.
Old 09-08-2005, 12:12 AM
Well, I think I fixed it. I found the right rear wheel cylinder leaking when I pulled back the boot. I replaced the wheel cylinder and blead the system. Drove it around for a while and the pedal seemed to be back to normal. I guess the real test will be driving to work tomorrow morning. Thanks for the help everyone.
possible hard pedal blackbeard Suspension - Brakes - Steering 16 01-10-2005 07:23 AM
92 rodeo pedal to the floor 87442lover Suspension - Brakes - Steering 3 11-17-2004 06:39 PM
Brake pedal to the floor 87442lover Suspension - Brakes - Steering 5 11-12-2004 10:59 PM
floor mount clutch pedal 6speedwagon Transmission - Rearend 0 03-09-2004 02:45 PM
Try this on the wife Gr8 '48 bow tie Hotrodders' Lounge 3 09-18-2002 02:04 PM
