Pedal Pads made from 50 cent flip-flops. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 08:38 PM
cboy's Avatar
Last journal entry: Finished
Ever had your pedal pads start showing ugly wear and tear and wonder how to spruce them up for less than 50 cents? Here's how I just did it for my sedan/delivery.
These were the old pads from the donor vehicle. Worn and ugly as sin.
I had already cleaned up and powder coated the pedals themselves. But I was in dire need of something interesting and unique to cover them with.
Then I stumbled on a couple pair of flip-flops I had scored for 50 cents when a local gift shop had gone out of business.
I cut our the shape of the pad on my band saw, smoothed the cut edges with 180 grit sandpaper and then used contact cement and 4 screws to attach the pads to the pedal faces.
Here are all three pedals completed.
And here they are hung in the car.
Now I just need to find a buyer for these slightly used, low mileage, air conditioned beauties.
[As always, you can find complete step by step pictures and details of this project in my journal here. ]
Always learning...and sharing what I've learned.
Old 04-03-2010, 09:53 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Those look awesome! For anyone looking for cheap flip flops (not as cheap as $0.50, but still...) Old Navy sells flip-flops in about a billion different colors. 2 pairs for $5. If you really got a hair, you could color code your pedals to your interior or exterior.
Once again, very cool!
Old 04-03-2010, 10:40 PM
cboy's Avatar
Which raises a couple other points. If you have a choice, always buy the largest size available. Because of the holes in the flip flops, you have to maneuver around a bit to get enough material to cover your pedals, particularly if you pedal faces are on the large size. Also, you will definitely need one "shoe" per pedal. So if your car is like mine, you'll end up using three flips and have one flop left over. Which you can then donate to the Pirate Welfare League.
Old 04-03-2010, 11:09 PM
Great Idea
I have a few of the top plates from conveyor chain that I plan to use for pedals down the road. around 1 1/2" X 2 1/2" steel with 2 stainless rivets in the center/
Shane
Old 04-04-2010, 04:12 AM
jon72vega's Avatar
WOW, I could have had a V8!
That's pure genius!!!
Jon
http://1972vega.wordpress.com/
Old 04-04-2010, 11:47 AM
cboy's Avatar
Originally Posted by Chevrolet4x4s
... with 2 stainless rivets in the center...
Thanks for throwing in your plan, Shane, because I failed to also mention that one can easily drill the holes in the backer plates completely through the pads and then add nice, stainless, rivets or bolts to give the pads a bit more "racing" flavor. The pads are thick enough that you can also counter sink the holes on the face side so that the bolt or rivet heads are flush with, or below, the face of the pad.
Add that to the idea that you can get flip-flops in all different colors and you can start to see the wide range of personalized and custom applications this might take on. And at relatively little expense.
Can't wait to see what some others might come up with for ideas.
Old 04-04-2010, 12:07 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this in General Rodding Tech, too.
Dan
Old 04-04-2010, 02:09 PM
cboy's Avatar
Good by me. Didn't know where it would fit best.
Old 04-04-2010, 11:22 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Pretty innovative idea there!
The true spirit of hotrodding... being resourceful.
Old 04-05-2010, 12:15 PM
techinspector1's Avatar
Wiki Edits: 326
Pure hotrodding at its finest....
Cboy, your pirate donation did not go unappreciated...
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Made in............ Henry Highrise Off-Topic 3 03-30-2008 09:54 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
