Pedal ratio
I need to build a pedal and master cylinder bracket for a street rod..we are using a manual master cylinder and need to get some Idea on the pedal ratio so we can draw up a plan for this thing..the bracket will incorporate the pedal and mastercylinder mount and the whole works will then be bolted to the chassis in the appropriate spot..
Thanks Sam |
1 Attachment(s)
Check out wilwood, I used the single pedal with the duel master clyinder. They also have hanging assemblys
http://www.wilwood.com/Products/005-...smcp/index.asp |
Russ |
I usually make my brackets and pedals so that the ratio can be changed if needed. Manual discs take a bit more ratio, at least 6 :1, maybe more.
Later, mikey |
Thanks guys..I think I have it whupped..I will know when I go to drive the car if it works out ok..
Thanks Sam |
| All times are GMT -6. The time now is 09:44 PM. |
