Pedal ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2008, 10:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Pedal ratio
I need to build a pedal and master cylinder bracket for a street rod..we are using a manual master cylinder and need to get some Idea on the pedal ratio so we can draw up a plan for this thing..the bracket will incorporate the pedal and mastercylinder mount and the whole works will then be bolted to the chassis in the appropriate spot..
Thanks
Sam
Old 09-05-2008, 12:12 PM
35chev/302gmc's Avatar
Check out wilwood, I used the single pedal with the duel master clyinder. They also have hanging assemblys
http://www.wilwood.com/Products/005-...smcp/index.asp
1935 chevy,masters
Old 09-05-2008, 05:00 PM
S10xGN's Avatar
Gotta love a turbo!
Thanks
Sam
Most factory manual brakes had a 6:1 pedal ratio...
Russ
Old 09-05-2008, 07:31 PM
powerrodsmike's Avatar
Wiki Edits: 161
I usually make my brackets and pedals so that the ratio can be changed if needed. Manual discs take a bit more ratio, at least 6 :1, maybe more.
Later, mikey
BE different....ACT normal.
Old 09-05-2008, 08:42 PM
Wiki Edits: 3
Thanks guys..I think I have it whupped..I will know when I go to drive the car if it works out ok..
Thanks
Sam
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
brake pedal ratio yragat Suspension - Brakes - Steering 15 04-08-2008 09:35 AM
Brake Pedal ratio: manual-to-power conversion wfritchen Suspension - Brakes - Steering 2 06-21-2007 06:12 PM
Clutch pedal ratio? Super Chevy General Rodding Tech 5 04-13-2006 02:55 PM
