pedals - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2008, 08:12 AM
pedals
Does anyone know of a street rod vendor located in Kansas or possibly Oklahoma that goes by the name of Hot Rod Garage (or something similar) ? Specifically I am looking for any vendors who make pedals that are drilled w/some sort of non -slip insert added. If I remember correctly, this shop had clutch, brake & gas pedals that had drilled holes for that hot rod look, plus small, round rubber bumps added for slip resistance.
However, if you know of other vendors, pls. let me know. I don't have any pedals right now, or else I would drill them myself.
This is for my 33 Ford.
Thanks,
Mike.
Old 03-22-2008, 12:36 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Hi Mike: I'm going to move your post to General Rodding Tech. I think you'll get more and better answers there. I'll leave it in the interior section as well. Good luck finding what you're looking for.
Dan
Old 03-24-2008, 04:03 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Can't remember anything that was drilled, but there are pedal companies that have pedals with rubber/vinyl ribbed "non-slip" pads that are glued to the pedals. Try Yogi's Hot Rod Shop in IA.
Old 03-24-2008, 06:38 PM
pedals
alitttle1,
Thanks for the comments. I looked @ Yogi's web site & this is not quite what I had in mind. The pedals I'm interested in have round drilled holes & were chrome or stainless.
Thanks again,
Mike.
Old 03-24-2008, 08:06 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
Thanks,
Mike.
I have seen a set of pedals like you decribe. They are sweet and they also make a manual matching shifter. I can't remember the name but I know theres a machine shop in Milford Ohio that makes them. Milford is a small place, so I'm sure there aren't to many machine shops.
Good luck
Wilwood Pedals and Master Cylinders Dugg Suspension - Brakes - Steering 17 02-04-2008 02:53 PM
Under Dash Master/Clutch Cylinders Pedals 1930u Suspension - Brakes - Steering 7 06-05-2007 08:18 PM
Need Help with a brake booster and pedals bracket on firewall! streetrodder31 Suspension - Brakes - Steering 13 02-26-2007 11:55 AM
brake/clutch pedals on '39 Ford sandman351 Suspension - Brakes - Steering 2 01-04-2005 09:44 PM
Primer /paint combo for pedals & dash braces gsrokmix Interior 7 12-25-2003 10:55 AM
