Peel and stick on roof - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2008, 03:49 PM
I've been reading some of the old archives and am leaning towards using the peel and stick foil type material to deaden the sound on the roof and then use a lightweight headliner material on luan or some of the plastics. I've got the roof cleaned down to bare metal, has anyone had trouble with the peel and stick coming loose? and then I was at the junkyard (salvage recycling center) and noticed that some of the headliners use a perforated material to which the foam backed cloth material was attached, I was thinking that noise would go through the perforations and get muffled in the foam. Am I way off on that or was it just cheaper and lighter weight for the manufacturers to use. Thanks, Eric
Old 02-05-2008, 04:47 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have used the foam backed cloth several times over the years and it works pretty good.
Old 02-05-2008, 07:32 PM
302 Z28's Avatar
On overhead and vertical surfaces you need to augment the peel and seal with some spray contact adhesive. Use a 3M interior contact adhesive or Hi temp contact adhesive. DO NOT use 3M #77 contact adhesive, it will not hold when the roof gets hot.
Vince
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
peel and stick window tint SDSJap Interior 4 08-22-2004 06:36 PM
