penetrating oil soaked primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 07:31 PM
atotalnincompoop's Avatar
Last journal entry: 46 mercury bobber pickup
when we were disassembling my 58 caddy we used some penetrating oil to help remove some of the moldings.
the body work was done and the car was primed.
some of the oil has soaked into the primer around the molding mounting holes.
can this be sealed somehow or what can be done to remove it from the primer?
Old 04-23-2009, 08:24 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Sunlight dish soap and water used with a stiff brush will do the trick.
Old 04-23-2009, 08:50 PM
fast68's Avatar
likes chevy trucks & boobies
hmmmmm ive always wondered
but never put much thought into it
but yeah. soap and water makes sense to me
the enemies of oil
good luck!
Old 04-24-2009, 04:01 AM
i hadn't thought of basic soap and water, kinda obvious i guess .
perhaps i was over thinking it
thanks
oil psi problem w/350 A355CAMARO Engine 1 04-19-2007 07:25 AM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 02:34 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
