Pentium 4's and dual channel memory - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2004, 12:01 AM
4 Jaw Chuck's Avatar
I am looking into replacing the old trusty Athlon 700 here at home and have been looking at the dual channel memory available for the Pentium 4 chip to take advantage of the "hyper threading" technology. Basically I would need a Mobo with dual channel memory and a couple matching sticks of ram (in my case 512Mb each). This costs a significant amount extra and I was wondering if it is worth it?
I run a lot of the latest games (UT2003, Comanche 4, Simcity 4, Ravenshield etc.) and do a lot of photoshop work so if the increase in speed is substancial I would be willing to invest in the latest tech. I am also considering an ATA drive at the same time since all these new Mobo's that come with dual channel memory support this new standard.
Has anyone tried this new hardware and have a comment pro or con? Is it worth mixing old tech (EIDE) with the new tech or does the advantage go out the window? I've read the tests and to be honest they mean nothing in the real world, I want an experienced opinion.
Thanks in advance.
— Han Solo
Old 02-25-2004, 12:54 AM
akm akm is offline
i just wish i knew what the hell you just said.
Old 02-25-2004, 12:58 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Huh?
Old 02-25-2004, 01:11 AM
Sorry, replace "Mobo" with the word "motherboard". Does that make more sense?
— Han Solo
Old 02-25-2004, 01:21 AM
FASTCHEVY's Avatar
I have some frends that speek computer nerd, and would know
what you're talking about.
Hey may be you can help me setup my digital camera?
it's a 4.1 meg. and it's got a little plug on it that won't fit anywere
on this dinosour computer. is there some kind of kit or dock I can
use?
Thanks.
Old 02-25-2004, 01:25 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
i'm not a computer nerd and i knew what a mobo was......
FastCHevy, you need a usb port. they make a hub type thing that plugs into the port in the back, sits on your desk, and has multiple usb ports available.
hey 4Jaw, how much you want for the old 700???
that would be a big step up for me, as i'm still running a 466!!!
troy-curt's Avatar
Shop Owner And Troll Hunter
Chuck;
Here is what I'm using on my build. Well let you know in about a week how it works, just waiting on a few more items.
Cases (Computer Cases, ATX Form)
AOpen Case with 300W POWER SUPPLY with USB ports (Red), Model "QF50C" -RETAIL
Specifications:
Form Factor: ATX/microATX/flexATX
Color: Silver/Red
Material: Metal
Drive Bays: 5.25" x 4/0, 3.5" x 2/1 (external/internal)
Expansion Slots: 7
Front Ports: 2 USB / Ear phone / Mic. In (Optional)
Power Supply: 300W
Cooling System: 8cm optional 2nd DC fan
Motherboard Compatibility: ATX/microATX/flexATX
Dimensions: 17.32"(D) x 7.64"(W) x 16.77"(H)
Special Features: Bend-in edges ensure safe assembly and installation,Smart slide-in back bracket with no screws needed,Compact design saves space,Sliding-in/out side covers that make assembly easier
N82E16811130115 $40.00
Motherboards - Intel
GIGABYTE 865PE Chipset Motherboard for Intel Socket 478 CPU, Model "GA-8IPE1000Pro 2004 GT Edition" -RETAIL
Specifications:
Supported CPU: Socket 478 Intel Pentium 4 Processors(Hyper-Threading)
Chipset: Intel 865PE + ICH5
FSB: 800/533/400MHz
RAM: 4x DIMM for Dual Channel DDR400/333/266 Max 4GB
IDE: 2x UltraDMA 100/66/33 up to 4 Devices
Slots: 1xAGP 8X, 5xPCI 32-bit
Ports: 2xPS2,2xCOM,1xLPT,1xLAN,8xUSB2.0(Rear 4),Audio Ports
Onboard Audio: Realtek ALC658 6-Channel Codec
Onboard LAN: Intel 10/100Mbps Ethernet
Onboard SATA: 2x Serial ATA
Onboard 1394: T.I. IEEE 1394 Controller
Form Factor: ATX
N82E16813128216 $96.99
Processors
**This item is NOT REFUNDABLE, exchange for same exact item only!!**
Intel Pentium 4/ 3.0C GHz 800MHz FSB, 512K Cache, Hyper Threading Technology - OEM
Specification
Model: Intel Pentium 4 3.0C w/ Hyper Threading
Core: Northwood
Operating Frequency: 3.0GHz
FSB: 800MHz
Cache: L1/12K+8K; L2/512K
Voltage: 1.525V
Process: 0.13Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2
Packaging: OEM
N82E16819116163 $219.00
C261-6043 Connect 3d Radeon 9200 Video Card / 256MB DDR / AGP 8X / TV Out and DVI---$124.99
Shipping and Handling Charge »$15;00
Also using western Digetal Special Edition SATA Hardrive 200
GB. $229.00 W/$60;00 rebate.
And matched ultra 512 MB DDR 444 strips--$149.00 W/ $50.00 rebate.
Got a new DVD burner for Christmas, thats what started this project.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-25-2004, 01:34 AM
FASTCHEVY's Avatar
OOOOH I want one of those thingies too!
USB huh, I gess I can pick one of those up a Best Buy.
Old 02-25-2004, 02:42 AM
Now thats what I'm talkin bout Troy! That should be one heck of a screamer. I already have a 9000 Radeon that works fine for the games I am running but I wouldn't mind stepping up, it's only 4X AGP and from what I am seeing for sale thats old tech already!
I'm torn between spending a few more bucks and building a similar system or just staying midstream and save the money, some pretty good deals for around a grand up here. The line seems to be drawn between the old motherboards supporting single channel and the new stuff at the bleeding edge. I do like the Hyper Thread idea, and from what I have read it really comes in handy for a lot of the work I do on the PC. The dual channel memory thing I am not so sure about.
One thing is for sure, I am sick and tired of listening to all the fans running in this thing, there is absolutely no need for there to be three fans in one computer. This overclocker case design using fans is ridiculous. What the heck ever happened to the silent PC? I miss my old Pentium 75 laptop, not a single fan in it.
Kept your lap warm though!
I afraid the little ones have first dibs Larry, Luke is already a whiz and plays GTA3 better than myself. I guess one day I will have to explain why picking up ladies in the car and taking them to the park gives him 5 more health points. I am an evil father to expose my children to such violence.
Pray for my soul.
— Han Solo
Old 02-25-2004, 09:23 AM
troy-curt's Avatar
Yeh, I could have built something for a few hundred less that would do every thing I want to do, and be compatible with anything new for the next few years. Going this route I know that I'm on top of the latest technology, and will have plenty in reserve.
Some of the capabilities of this MB are assume. And there is some that will do even more than this one.
I'ts kinda like my cars I tend to go beyond what is necessary.
Some of the features of this system I do not understand yet, and may never use them. But they will be there if I want to.
There is some people on here that can explain what all of this new stuff is. Gen3_with_455, 68 Imp, Native Gearhead and Jag. to name a few, They helped me a lot.
A year ago, the only computer I knew was the work order Invoice computer at the shop and store. Now I know how to turn on a PC. eh.
PS. If you see the Dejoys and the Nickles at the show there this year tell them hello for me.
Troy
Old 02-25-2004, 10:35 AM
Steve karch's Avatar
Don't you be talking about my Mother like that!!
Old 02-25-2004, 11:17 AM
poncho62's Avatar
Wiki Edits: 5
All I hear is
"BLAH, BLAH, BLAH"
I'm just learning to type with more than 2 fingers, for petey sakes.
Old 02-25-2004, 11:27 AM
That's pretty good Poncho, how many fingers. I'm up to 3 now. Index and middle on the left hand and the middle finger on the right hand.
Old 02-25-2004, 11:29 AM
troy-curt's Avatar
Your doing good. I use one finger lol.
I should get back to using all fingers, I used to.?
Troy
Old 02-25-2004, 11:32 AM
poncho62's Avatar
Wiki Edits: 5
My middle finger has another job..........
I know, I should get into "Multi tasking"......lol
