Percy screw holley Jet adjuster plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 10:36 PM
spinn's Avatar
Anyone use the Percy jet Adjustment plate for holley carbs? Allows for increase or decrease of holley jet orafice size by the turn of a external screw.
Do you use it only on the primary side? Is it good?
Seems like a good idea. No fuel mess, changing jets on the fly.
Old 06-28-2010, 08:37 PM
I still have a set of those I used on a carb (both ends)on my dragster, they worked fine car ran as good with those as with my AED carb. And they are easy to adjust
Q jet VS Holley?? Trav Engine 37 03-06-2007 06:11 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
Holley jet question...... BstMech Engine 2 12-31-2003 03:49 PM
holley adjust a jet 6speedwagon Engine 0 09-29-2003 11:41 PM
holley jet numbers fordracing Engine 1 03-31-2003 06:37 PM
