-   -   perfect paint job (http://www.hotrodders.com/forum/perfect-paint-job-223663.html)
acman 09-03-2012 08:42 AM
perfect paint job
if i sandblast to bare metal do I still need to do 80 grit DA scratches?
timothale 09-03-2012 10:47 AM
sand blast ?
I had my model A pickup bed sand blasted and even after washing, blowing with air a few times I still ended up with sand in the color coat. I only sand blast bits and pieces that can't trap sand.
MARTINSR 09-03-2012 11:44 AM
What do you plan on sand blasting? DO NOT sand blast sheetmetal body panels! It is VERY dangerous as you can warp them VERY easily.
But if a piece of metal sand blasted doesn't need any sanding unless it was pretty coarse sand that was used to blast it. In that case 120 would be better.
Malibusurfer 09-06-2012 09:55 AM
I have always sanded with 80 grit with a DA after sandblasting!! Primer is a mechanical bond and those scratches make a great base. Also DA'ing you get rid of any dust etc hiding in crevices ( microscopic ) that sandblaster made that air may not be able to get out. Not sure if I need to, I just always have and never have had an issue..
