Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Perfect Rod Kit.
Old 08-05-2008, 09:24 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Chassis: 33/4 ford repro, with an 8 point roll cage for extra stiffness. Put a 33 sedan body on that.
Suspension: 4 link w/ coilovers rear, 6" dropped tube axle with coilovers and 4 bar.
Differential: narrowed Dana 60 with a locker and 5.86 gears
Engine: Carrol Shelby aluminum block 427 side oiler motor punched out to 526" with a Whipple supercharger., moved back in the frame about a foot. (So's I can be closer to it when I'm stabbin the gas.)
Transmission: 5 speed lenco. ( real hotrods have a clutch)
Steering: 525 box and cross steer.
Later, mikey
BE different....ACT normal.
