you need a flow bench.The bore size has to be adjusted to match your engine.The tech will take readings at .3,.4,.5 inches of lift. with near stock parts you will get moderate improvements over stock ratings
The intake and carb were off a late 70s Chevy 400 engine, right now the engine is on a break-in stand and as far as exhaust all i have on it is headers, they have 3in outlets, thats all i know about them, i am borrowing them
Thats not a Mild cam" when used in a 305. It will have lame power below 3500+ rpm.
Will need a loose very high stall race converter and very high rear end gears. Event the best of the 305 heads have very modest port flow in stock OEM form. Don;t expect big power from this motor with stock non ported cylinder heads. If you were to fully port the stock heads and use a better intake+ headers it would make some power The engine will be a dog below 3500 rpm . No torque and won;t make the big power you think. The compression ratio will not be even close to 11:1 without a domed 305 piston. with a flat top 305 piston and .040" gasket and 54cc heads the cr will be almost 10:1 I hope you got some 4.56 gears an a 4000 stall race converter.. Good thing there are many more cams to choose from. pick a much smaller camshaft that matches the vehicle, engine and purpose. To get the 305 to idle with this big cam in it lock out the distributor mechanical advance system and set the locked fixed timing at 34-36deg BTDC, then plug the vacuum advance to the ported vac source on the carb. Big cammed motors need a lot lot of spark advance at idle to idle nice. Otherwise it will cough spit, heat up, back fire and stall etc etc. 34-36deg locked timing at idle. what is the Vehicle this motor is going into? Last edited by F-BIRD'88; 11-18-2012 at 11:19 PM. |
Horsepower? Well..... not much i'm afraid. First rule of engine building: "there is no substitute for cubic inches" Second rule: "power-adders are your friend!" Third rule: "be rich. this is not a poor mans hobby" ( That's all for now. Good luck )
Your cam is bad, but even worse... you started with a 305. It's okay though. I'm sure you learned some good lessons you can apply to your next engine build. ( Think: CUBIC INCHES )
| Don't You Hate It When..... | boggla500 | Hotrodders' Lounge | 9 | 04-09-2010 01:57 AM |
| Please don't hate me, but | NOlowrider | Engine | 24 | 01-04-2005 06:35 PM |
| Don't you hate it when... | RetroJoe | Hotrodders' Lounge | 18 | 09-19-2004 12:10 PM |
| Don't Hate Me! | pookie1205 | Hotrodders' Lounge | 33 | 11-16-2002 10:33 PM |
| Hello to all, don't hate me.... | 94SSEiDu | Hotrodders' Lounge | 5 | 03-18-2002 03:45 AM |
