Performance Engine Parts..PEP - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2010, 02:34 AM
327NUT's Avatar
Has anyone used any of their parts? I scored a 500" Cadillac and T400 trans for $250 with only 40K on a .030 rebuild. I pulled the heads and intake and this thing is really clean inside and you can still see the cross hatch pattern in all the cylinders. Will probably just kiss it with a hone for moly rings and replace all the bearings for good measure. Just going to be a cruiser but would like to take it up to 4500K now and then.
Going to do a mild perf. build for a future project but I read that the conn rods and bolts are very questionable around 4500 rpm along with the rocker assemblys. Several of the hipo Cad outfits have several different shaft mounted rockers in varying dollar amounts. One of the web sites says that the con rods are Cast not forged, anyone have the straight scoop on that?
Anyway getting back to PEP, they sell a forged 4340 I beam rod both in bushed and pressed fit with ARP cap screw bolts for under $300. Yes, I know they are forged in China (what isn't?) but machined in the USA. So do we have any Cadillac afficienado's out there.
Old 08-13-2010, 02:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Rods are cast. Fine to 4500 RPM w/resize and bolts. Crank strong as-is. Valve train is flexi-flyer. Thicker walled push rods at a minimum.
Old 08-13-2010, 05:46 AM
ericnova72's Avatar
More for Less Racer
Only thing PEP I have used is SBC head bolts, the same bolts GM uses on the Vortec engines. They come with the outer row short bolts zinc plated to prevent rust and all come with preapplied thread sealer on them. Good value for the low cost of just $21 a full set, use them on all my SBC builds unless the owner wants to spring for ARP, no troubles with the PEP so far.
Only thing I would say about the rods is have them checked for big end roundness and correct bore sizing, just like you should with any Chinese rod. Seems like a good price.
Stock Cad rods are Cast Armasteel, just like Pontiac V8.
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
intake leak? cope Engine 4 05-08-2008 07:59 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
Need improved engine performance Rancher2 Engine 1 11-26-2002 02:10 PM
