Performance gains from hyd. to mech. cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 03:35 PM
what you all think i would gain switching my hyd. flattappet 241 249 @ 50 .525 .546 cam on a 11 to 1 383 with bowties to a solid cam bout the same size ?
Old 08-06-2010, 03:50 PM
Solid cams require a slightly larger size due to the lash. I'm not a cam expert but if I had to make a guess I would say about a 5% increase of a solid over a hydraulic- assuming they have simmilar designs (which is a big assumption).
Modern hydraulic cams can do better than out dated solid cams.
There is also more to consider than the lifter, I would consult a cam expert, meaning a real cam guy, not the tech line for a major cam manufacturer.
Old 08-06-2010, 04:23 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Of all the many posts I have read on here , and I mean many , I have not once seen anyone suggest going to a solid lifter cam as a means to gain performance . So , to answer your question . You stand to gain valve train noise and the extra maintenance to periodically re-adjust valve lash . JMO
Old 08-06-2010, 04:26 PM
Then you need to read more. There is an advantage. If there wasn't one then racers would run hydraulics...
Old 08-06-2010, 04:28 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
The main attributes to a solid flat tappet cam are that they are cheap to buy and they will rev to the moon, or at least they will rev until something else breaks.
Agree with adantessr, looks like a lot of work for nothing to me unless you have a bulletproof bottom end and lightweight valve train and want to take your chances with a flat tappet cam and an overabundance of valve spring. Good luck.
Old 08-06-2010, 04:35 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I wasn't aware that he wanted to race it and run sustained high engine rpm , If that is what he intends to do then , yes lifter pump-up is a factor . For street use , stick with the hydraulic cam .
Old 08-06-2010, 06:07 PM
Solids also have faster ramps and can take higher spring pressures. Hydraulics are easier for sure but solids are better in every other aspect. Rather flat or roller faced.
Old 08-06-2010, 06:20 PM
Its for street strip use if its not gonna gain me 20 0r 30 hp i will stick with what i got just lookin for cheap hp lol
Old 08-06-2010, 06:33 PM
Well the power gain on a 450hp sbc would probably be around 20+hp (if you selected the right cam) but the cost is a little higher if you run good springs and face oiling lifters. I prefer solids but it does require occasional lash adjustment and a little more money. The next step would be going roller.
Given the right cam and lifter combination a flat mechanical can beat a hyd roller. That requires a very large cam journal and mopar lifters though.
Hyd flat tappet cam valve ajustment???? gofastz Hotrodding Basics 7 06-14-2010 08:00 PM
How can you tell solid from hyd. cam? redride Engine 6 03-15-2009 11:47 PM
Poll... on the sound of solid VS hyd cam sound. Blown72Camaro Engine 12 05-28-2004 05:56 PM
Solid vs Hyd Cam choice Dubz Engine 6 03-08-2004 10:15 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
