Performance Gains from Larger Valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2008, 10:17 PM
fast4motion's Avatar
Hi
I have a street-driven supercharged 400 Small Block Chev, which is running standard heads with 1.94 inlet & 1.5 exhaust valves.
I have the opportunity to purchase some heads with 2.02 & 1.6 valves.
Could anyone tell me if there would be noticeable performance gains from the larger valves?
Cheers
Old 07-19-2008, 02:54 AM
Current heads are original smoggers with some port work done (3973493 - 76cc).
Heads I'm looking at are also smoggers of the same era, just with bigger valves (3973487 - 75cc). They're originally from a 350, so I'd need to drill steam holes in them.
Engine is a 4-bolt 400, with nothing radical done to it (other than the blower).
It has an ARP head stud kit, Summit cam (#1105), dual valvesprings, Harland Sharp 1.6 roller rockers and stud girdle, MSD ignition.
The bottom-end is pretty much standard, just with good quality rings and bearings. This is because I don't want to invest in expensive pistons/rods/crank etc for the 400, because it's already bored to it's limit. Otherwise when it's time for a rebuild, I'd need to find another 400 so I could re-use my good parts.
I'd rather wait until it gives up, then get a new 350 block, and invest in quality parts for that, which I can re-use in future.
In saying that, I fitted the blower in 1997, so the motor is doing pretty well!!!
I nearly forgot, blower is a Weiand 6/71, with dual Holley 600 vac-sec carbs, which I'm currently rebuilding and boost referencing the power valves.
I've always wanted/planned to buy good aftermarket heads, but was gonna wait until I got a new 350 block first, which might be years away!!!
That's why I was wondering if the gain in performance is worth the trouble/expense of fitting similar heads with larger valves.
Old 07-19-2008, 05:09 AM
Thanks for the info.
(The stud girdle is only there because I got it for free )
I used to look at heads on the internet, but got frustrated finding good flowing heads with large combustion chambers. Most top quality manufacturers I looked at only really did high compression heads, although I see there are a lot more options now.
Then I think about having to drill steam holes in brand new heads , and eventually come back to the plan of building a complete new 350 engine.
And my 400 is still going strong, and making enough power as it is. I mainly use it just for cruising now anyway.
I've decided not to worry about the heads. I'll just keep an eye out for some aftermarket ones advertised for a good price, or most likely wait and splash out if I decide to build a complete new engine.
Cheers.
best way of adjusting valves SBC ??? Augusto Engine 33 03-22-2011 05:04 AM
New valves old seats? blacklabzeke Engine 2 05-29-2008 09:41 AM
Stealth marketing bust: Race Ready Performance Jon Hotrodders' Lounge 0 03-20-2008 02:05 PM
valve springs, valves, push rods, and rocker arms elcaminodragster Engine 7 01-28-2008 08:48 AM
Building a 671 SBC Motor TheAmericanDream Hotrodding Basics 5 06-13-2007 08:50 PM
