performance parts for 305? 86 caprice classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 06:59 AM
i was wondering if i can atleast get 300 hp out of my 86 caprice with a 305? or would it cheaper getting a 350 and buildng from the ground up? i know to replace headers and other parts but what parts would squeeze the most power outta my 305 without boring the cylinders. thanks in advance
Old 05-11-2011, 08:55 AM
badknuckles's Avatar
you talkin to me?
You can try, you should work on torque and not hp though. From my experiences resistance is futile and the 350 is the clear cut easiest way to hp and tq
Old 05-11-2011, 11:36 AM
Cheaper to build a moderate powered 350 at 300 horses and it will have much better street habits. The 305 pushed to 300 horse will require more and less street friendly tricks that raise the cost and reduce comfort range.
Like any engine, the cam and heads are the key. But pumping up an old engine usually results in other problems related to age wear of the bottom end. These type top end modifications on a high mileage engine usually result in excessive oil consumption from the get-go and bearing failures a bit further down the road because the pistons, rings, bearings as well as the oil pump and other bottom end parts are worn out. The engine has been loosing power for years so the stress and strain on these old parts has been going down. When you put a big cam and better breathing heads on top of these old guys they just get pushed beyond their current capabilities and quickly loose whatever life is remaining. Automatic transmissions are the same way, they wear about the same rate as the engine, so when you add power to the engine or replace it, the old automatic's life becomes measurable in weeks to a few months.
This is just not easy to pull off on a shoestring budget, which is why I recommend just buying new or rebuilt replacements rather than trying to piecemeal these jobs as the major components will usually die faster than the bank account can be rebuilt and you find yourself with a broken, non running car and no more money all at the same time.
Bogie
will 91-96 caprice suspension parts and rearends fit in my 85 caprice? ironindian77 Hotrodding Basics 20 11-15-2012 09:29 PM
76 caprice classic colalpha Introduce Yourself 1 07-22-2005 02:22 PM
Parts catalog for a 75 caprice classic hotrodgrasshopper General Rodding Tech 2 07-10-2005 04:26 PM
anyone use Classic Performance Parts drop springs?? 69elcaminoss Suspension - Brakes - Steering 1 03-29-2004 09:22 AM
LOWERING 75 CAPRICE CLASSIC FASHIONPOLICEx Suspension - Brakes - Steering 4 03-12-2003 12:14 AM
