Performer Cam Vs Higher Compresion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 02:16 PM
swompz's Avatar
Ive already Had little feedback on this but as always like to hear more than one opinion.
can anyone tell me or direct me to were I can find out if a sb Chevy performer cam would work with a 350 engine with a static compression ratio of around 10.02.1 ??
If it will Ill be a happy boy as wont need to buy a new cam.
cam specs as follows.
BY2291730 262-400 1957-94 "Performer" flat tappet camshaft- idle to 5500rpm �70.09
Duration @ .050" lift = In 204, Ex 214, Valve lift = In .420", Ex .443", Lobe sep 112.
Use springs BYVS-677
if not does anyone have a cheap recommendation ? if I could re use my new
vs-677 springs it would be another bonus.
thanks
Old 05-24-2012, 03:19 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
From those cam specs I am thinking you are too high on the compression for that cam. However that is speculative.
Find out the intake closing point of the cam, plug it into this calculator along with the other engine specs etc and see what you come up with. Dynamic compression ratio is important to determine cam selection.
http://kb-silvolite.com/calc.php?action=comp
List the aspects of the vehicle weight, trans type, rear gear, tire size all these have a say as well
Edelbrock Performer RPM Cam manchildau65 Engine 22 08-03-2015 07:42 PM
Edelbrock Performer RPM cam pds23 Engine 3 10-07-2008 06:24 AM
Performer Rpm Cam thefloyd1973 Engine 3 04-27-2007 08:29 AM
Edelbrock Performer Cam vs. ... hillman88 Engine 21 05-13-2006 08:06 AM
Anyone ran the Performer RPM cam f355bird Engine 18 03-19-2005 02:38 PM
