-   -   Performer eps manifold.... (http://www.hotrodders.com/forum/performer-eps-manifold-136196.html)
DarknessSpawned 04-01-2008 04:54 AM
... The manifold I have , but have no gaskets, Looked up the manifold and the gasket suggested has just 2 peices, None for the front back end of the manifold, I guesss just seal that up with gasket sealer??
darom 04-01-2008 07:38 AM
Yes, I always use the gasket maker (Permatex Black RTV). It seals well and never gives me issues later.
DarknessSpawned 04-01-2008 03:15 PM
Thanks, Just wanted to be sure about it.
75gmck25 04-01-2008 05:45 PM
Did you get installation directions with the manifold? The Edelbrock instructions (they are online) tell you to not use the end gaskets, and seal with a bead of RTV instead.
They also tell you which main gaskets to use, and a couple types/brands to avoid. The suggested gasket is a little thicker, and has a silicone bead around the water jackets.
Bruce
