Performer eps manifold.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2008, 04:54 AM
DarknessSpawned's Avatar
God Of Lightning
... The manifold I have , but have no gaskets, Looked up the manifold and the gasket suggested has just 2 peices, None for the front back end of the manifold, I guesss just seal that up with gasket sealer??
Old 04-01-2008, 07:38 AM
Yes, I always use the gasket maker (Permatex Black RTV). It seals well and never gives me issues later.
Old 04-01-2008, 03:15 PM
God Of Lightning
Thanks, Just wanted to be sure about it.
Old 04-01-2008, 05:45 PM
75gmck25's Avatar
Did you get installation directions with the manifold? The Edelbrock instructions (they are online) tell you to not use the end gaskets, and seal with a bead of RTV instead.
They also tell you which main gaskets to use, and a couple types/brands to avoid. The suggested gasket is a little thicker, and has a silicone bead around the water jackets.
Bruce
Edelbrock scorpion manifold vs performer RPM blow68 Engine 2 12-04-2007 06:52 PM
Intake manifold for Small Block Chevy???EdelBrock Performer vs. Victory Jr. 89SDime Engine 3 03-02-2006 10:53 PM
anyone compare a new EPS intake to a Performer? bullheimer Engine 5 02-20-2006 05:55 PM
oil fill tube install on performer manifold 1 Day Engine 2 10-16-2005 01:45 PM
Edelbrock EP4B vs Performer Intake Manifold Custom_Rods Engine 6 05-01-2004 11:46 AM
