Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Performer eps manifold....
Old 04-01-2008, 06:45 PM
75gmck25 75gmck25 is offline
Did you get installation directions with the manifold? The Edelbrock instructions (they are online) tell you to not use the end gaskets, and seal with a bead of RTV instead.
They also tell you which main gaskets to use, and a couple types/brands to avoid. The suggested gasket is a little thicker, and has a silicone bead around the water jackets.
Bruce
