Performer RPM Air Gap plenum divider info - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 07:11 AM
v8hed's Avatar
AK427
I've got a Performer RPM (non Air Gap) and would like to modify the plenum divider to match that of the Air Gap.
Can someone with a Performer RPM Air Gap laying around please measure the depth and length of the cut-out in the plenum divider? Saves me guessing from pics.
Thanks.
Old 07-25-2011, 07:21 AM
delawarebill's Avatar
air gap
i'm using the air gap.. don't know the numbers your looking for but i'd say 1/2" down and ~3" cut out... BUT... i closed mine in because it did not perform the way i liked it.. ran much better closed off..
Old 07-25-2011, 07:25 AM
v8hed's Avatar
AK427
Really? The plenum cut-out is the biggest difference between the Air Gap and the non-Air Gap (despite the name). On a test I found, the cut-out in the divider improved things all-round (this was in a big cam 383 exactly the same as I'm running).
What were your findings with and without the cut-out and what's the spec of your motor?
Old 07-25-2011, 07:36 AM
intake
i'm running a bored sbc 355, 600 edel carb and smooth idle cam. i honestly don't recall what it was doing for its been yrs.. i just remember is did run better with out it...
Old 07-25-2011, 09:21 AM
watch this you tube vid.. they do cut a small mortion of the divider like an air gap design on an non air gap style manifold.. they give the measurement of what they cut off which is what i think your looking for.. it will be twards the end of the video http://www.youtube.com/watch?v=i2DvnoHWagk
Old 07-25-2011, 03:36 PM
cool rockin daddy's Avatar
simply amazing.
Old 07-31-2011, 03:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks.
A 1/2" OPEN spacer will almost duplicate the cut down plenum divider. The more cam, the more this will help the upper end.
Old 07-31-2011, 04:22 PM
malc's Avatar
Living At The Speed Of Life
I´m using a non rpm Airgap with a two inch open spacer.
I went from a four hole one inch to an open one inch then ended up using the two inch.
From idle to WOT improved, idled like a pig with the four holer.
Old 07-31-2011, 04:59 PM
spinn's Avatar
Admittedly, my practice is to grind down the performer intakes divider. No more then a inch high. It is a good idea to port match them as well using a gasket template. You find it runs smoother, allowing more equal vacuum in the plenum. Gains in power are minor if at all, but the combined effort is hotrodding.
RPM Intake Center Divider ssmonty Engine 5 04-24-2009 10:22 PM
need info on Edelbrock rpm performer and.. ryork Engine 4 09-22-2007 04:23 AM
Need info about mercury couger plenum and throttle body mustang2 Engine 1 04-11-2007 08:14 PM
Edelbrok TORQUER II divider? Augusto Engine 17 07-10-2006 07:44 AM
droped plenum red_rider52 Engine 11 01-13-2005 02:34 PM
