-   -   Performer RPM Air-Gap plenum notch (http://www.hotrodders.com/forum/performer-rpm-air-gap-plenum-notch-231627.html)
v8hed 04-08-2013 07:30 AM
If anybody out there has a Performer RPM Air-Gap laying around, can you measure the length and depth of the plenum divider notch? Would really appreciate it.
v8hed 04-08-2013 11:49 AM
Originally Posted by F-BIRD'88 (Post 1664211)
If you have a non air gap RPM manifold do not carve the plenum divider.
Just try a open spacer. The effect is the same, and easily reversable.
Carving the plenum divider is not.
No room for a carb spacer.
v8hed 04-08-2013 01:17 PM
Hogg 04-08-2013 01:20 PM
6:15 of this vid.
Not sure what the measurement is.
peace
Hog
v8hed 04-08-2013 01:23 PM
Originally Posted by Hogg (Post 1664261)
6:15 of this vid.
Edelbrock Intake Manifold Dyno Test :: Single Vs Dual + Air-Gap Vs Regular - YouTube
peace
Hog
Yea, seen that... exactly why I want to do the mod :)
gearheadslife 04-08-2013 02:50 PM
D/f did this,, look up carjunkietv.com on you tube..
it shows the whole thing from carving the intake to the dyno room..
Weiand Vs Edelbrach intake manifold dyno comparison - YouTube "> Weiand Vs Edelbrach intake manifold dyno comparison - YouTube " type="application/x-shockwave-flash" width="425" height="350">
Edelbrock Intake Manifold Dyno Test :: Single Vs Dual + Air-Gap Vs Regular - YouTube "> Edelbrock Intake Manifold Dyno Test :: Single Vs Dual + Air-Gap Vs Regular - YouTube " type="application/x-shockwave-flash" width="425" height="350">
malc 04-08-2013 03:11 PM
I first had a 1" open spacer on my AirGap but as I had room I went to a 2" open.
Brilliant...:thumbup:
Previously I had tried a 1" four holer, the idle was terrible.
http://www.hotrodders.com/gallery/da...nch_Spacer.jpg
KA67_72 04-09-2013 08:28 PM
I have one for a BBC. The notch is 2.44 X .4 deep.
Kevin
ap72 04-09-2013 08:46 PM
The notch size is nothing special, every combo will want something different, especially depending on what carb is on top. Btw some people fill in that notch and get better results... As already noted its not easily filled and may NOT be a good move. I'd try a half inch spacer if space is tight.
