Performer RPM to RPM Air Gap Swap-350 chev - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 09:07 AM
corvette77's Avatar
Giddy Up
Just wondering if anybody has any advise on what sort of tuning changes can I expect when I swap this Performer RPM intake with a Perf. RPM Air-Gap ? I will be using a 1/2" carb spacer and the carburetor is a Holley 750 DBL pump, no choke or air-horn. I guess I just need to know if I should expect to change jets or Power valve or anything at all ? Thanks for your help.
Old 09-01-2008, 09:20 AM
04SilveradoMykk's Avatar
Tuning changes? none. it's a direct swap.
I like the air gaps, not necessarily for the "cooler" open intake runners... but you can feed vacuum lines, coolant temp wires, fuel lines.... etc thru the open center and it looks cleaner
Old 09-01-2008, 12:07 PM
You will need a manual choke to drive the thing below 50* temp.
Cold weather will be a pain, I promise you. You will probably need a carb air intake heater.
You will see little if any power gain between the manifolds.
Old 09-01-2008, 08:23 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You won't notice a darn thing. At best you might gain a couple HP. It also depends on the other parts of the engine; cam, compression, heads? Depending on how its set up, you could be going the wrong direction.
Air gaps don't make more power from a cooler intake charge because they reach the same temperature as non-air-gap, it just takes longer. During that longer warm up time you will experience a more "cold-blooded" operation.
Making a Edelbrock RPM into a Edelbrock RPM Air Gap black66 Engine 12 11-30-2010 02:31 AM
Whats wrong with the performer rpm cam?. 7fastelc0 Engine 19 12-09-2006 05:49 PM
The RPM Air Gap manifold PrimeMover Engine 32 03-06-2003 06:26 PM
edelebrock performer rmp air gap for sbc brian400ex Engine 2 02-11-2003 03:42 PM
