Permatex High Tack same as gasgacinch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2003, 11:49 AM
Post Permatex High Tack same as gasgacinch?
Edelbrock recomends this stuff called gasgacinch for installing an intake manifold. I couldn't find any around here except for ordering from Summit Racing, so i bought this stuff from Permatex called High Tack Gasket Sealant. Is it the same stuff? I think all it is supposed to do is hold the gasket in place while you set the intake on the engine.
Thanks
brian
Old 02-13-2003, 02:19 PM
Post
i always use a thin layer of permatex
Old 02-13-2003, 02:21 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Post
High Tack is good stuff. Still use permatex around the water passages.
The gasket will pull in two before the High Tack will let loose.
Old 02-13-2003, 02:35 PM
72 chevy's Avatar
Post
Edelbrock recommends it cause they sell it!! I used the permatex on my 2101, no problems.
[ February 14, 2003: Message edited by: 72 chevy ]</p>
Old 02-13-2003, 07:13 PM
E.T. divided by $ spent= Speed
Post
I allways use High Tack or that Indian head shalaqe in the brown bottle.Use that stuff on everything exept the pan and timing cover they get a tube of RTV Blue(I hate oil leaks).(also hate tryin to remove a pan thats been siliconed,but thats another story lol)
Also RTV the corners were the rubber ends meat the side intake gasets or just replace the rubber ends with high temp oil resistant silicone.
