Is Permatex threadlocker any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2010, 08:44 AM
Went to three auto parts stores this morning looking to get some blue Loctite for my cam & cam retainer bolts. Well, no one seems to stock the stuff anymore. All they have is Permatex. To make matters worse I'd forgotten my glasses, so I couldn't read the fine print on the back describing the applications. What I could tell was they seemed to have a pretty low listed temperature rating.
Is there a good Permatex to use on internal engine fasteners? Or should I continue to search for some Loctite?
Old 02-06-2010, 08:55 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Permatex is good stuff, used it for years.
Old 02-06-2010, 11:11 AM
sqzbox's Avatar
My pipes are my music
Go to their web site, click catalog, click threadlockers, and click loctite blue.
when the description comes up, just below that it has "WHERE TO BUY'.
A short form entering your address and city it will give you the nearest location to get it. www.loctiteproducts.com if you really want it.
Hope this helps.
Old 02-06-2010, 12:45 PM
Which threadlocker? Blue, Red, Green?
Old 02-06-2010, 01:17 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You want blue for the cam bolts. The blue is a "serviceable" type meaning you can remove them if needed. The red is high strength meaning it can be removed but requires the use of heat from a torch to break the bond. The green is a "wicking" type. There are no fasteners in an engine that should require anything other than the blue except maybe if you were installing head or main studs, then you may want to use red for those. Any threadlocker requires that the threads be well cleaned and primed with the appropiate cleaner & primer.
Old 02-06-2010, 08:01 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I use red for everything, and Permatex = Loctite,
Old 02-09-2010, 01:55 PM
Sorry for the hijack but I used red loctite for some flexplate bolts and its due for a freshening soon......will I pull the threads out of the crank flange if I don't heat it?
Old 02-09-2010, 02:09 PM
I myself have used the red locktite for three different cam swaps on my cam bolts and was able to get the bolts loose without putting heat to it. I just put the socket wrench on it and loosend it up. The stuff does work good from what I have read. I never had used blue or green. I would use read for any really critical bolts like cam bolts etc.
Eric
Old 02-09-2010, 02:55 PM
Rickracer's Avatar
No, and I'd use the red again when you go back together,
How good are pro comp cylinder heads automedics Hotrodding Basics 55 01-14-2016 02:19 PM
Yamaha Virago 750 Good Starter Motorcycle? mgold Hotrodders' Lounge 25 12-21-2009 06:38 PM
Good Tech School in Atlanta? mgold Hotrodders' Lounge 0 09-16-2009 08:12 AM
Good Place to get a Trans Built? YB2fast Transmission - Rearend 6 07-07-2009 02:41 PM
Good Hotrod Cam for 302 RetroJim55 Engine 11 11-07-2008 02:00 PM
