Perplexing fuel system question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2013, 01:00 PM
Hello:
This isnt really a hot rodding question, but you guys seem to be among the most knowledgeable on the internet, so I figured I would post this here. I have a Honda 8hp gas motor from the 70s that I picked up at a yard sale, rehabbed, and am now using to power an air compressor. The gas tank has a little stopcock under with a clear plastic bowl on it that is supposed to collect any sediment from the tank. I had to buy a new stopcock/bowl assembly as part of my rehabbing to get it running. The bowl has a little flange on it that allows it to be held onto the stopcock by a threaded ring. Not sure if I am describing this well enough. See the below exploded parts diagram (part #2).
The problem I am having is that the little bowl appears to be shrinking!! When I first got the part, it worked fine for awhile, then one day when I was about to run the motor, the bowl just fell out because the flange was too small. I figured maybe it had been just barely the right size and had stayed in there by luck, and I ground down a brass washer and made an adapter to hold it in there. Fast forward a year, and the exact same thing happened again. The bowl fell out of my adapter ring!! Is it possible that the ethanol in the new gas is eating away at the plastic? Or is something else causing the bowl to shrink?
If I have not described this well enough, feel free to ask me questions. Thanks for your help.
Old 06-29-2013, 02:04 PM
vinniekq2's Avatar
Tricity power equipment has a Honda mechanic that knows some of the older stuff.(bc) if you dont get an answer soon I will ask Gary after the long week end
Old 06-29-2013, 02:05 PM
techinspector1's Avatar
Wiki Edits: 326
You have nailed it in my opinion.
Old 06-29-2013, 02:47 PM
Yes it is shrinking
Hi all
You are on the right track.In the 80`s when gasahall come out I was changing fuel line`s and rebuilding carbs like there was no tomorrow.That is why it disapearded in 2 months.In the 90`s they played the game with 45 cetane for diesel and destroyed many injection pumps.And now the fuel has all kinds of junk in it.They the power`s that be want cars to be changed as much as possible.So that the roads only have new car`s on them.The kind that they can control. When was the last time you saw a gas sation have it`s tanks pumped clean of water.
2x4`s
Old 06-29-2013, 05:52 PM
BOBCRMAN@aol.com's Avatar
Yes, the bowl and the rubber seal on the gas tank filler cap. Ate up a couple of them on my tractor/mower.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
techinspector1 (06-29-2013)
Old 06-29-2013, 08:54 PM
LATECH's Avatar
If the bowl is plastic , it will shrink...decay.
Part number 1 also will crap the bed due to ethanol.
Fact is stranger than Fiction
Fuel System question Ratoflic Engine 5 01-23-2010 11:04 AM
Fuel pressure setting question for bypass regulator system hotrodf1 Engine 8 05-07-2007 10:26 AM
Fuel system question 475_enduro Engine 1 02-08-2007 10:23 PM
Perplexing steering problem BMM Suspension - Brakes - Steering 6 10-24-2006 06:02 AM
Last fuel system plumbing question (I hope) william27103 Engine 1 07-08-2005 09:57 PM
