Pertronics problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 06:06 PM
Pertronics problem
just installed a Pertronics kit in a '55 T Bird yesterday, it wouldn't start, found a bad coil wire, replaced it, it started, run, but poorly. Today, I put in a new set plug wires, (correctly ), now, I can't get the Pertronics unit to fire, it will only fire a spark when you first turn the key, and then again when you turn the key off,, nothing while cranking. What is the minumun voltage required to fire this Pertronics unit ?
Old 10-29-2012, 06:36 PM
302 Z28's Avatar
I'm not too keen on Pertonics ignitions. There have been a number of club members that have had failures and replaced them with MSD units.
Vince
Old 10-29-2012, 06:53 PM
Faith - Respect - Trust
Vince
I had a Pertronics distributor in a 428 Pontiac I built a number of years ago, same problem, swapped it out for an MSD, problem solved. This was the second Pertronics distributor I had that gave me grief, the other was on a 340 Dodge. Can't remember the exact problem on that one, all I know is that at higher RPM it would back fire. Went to MSD again and worked well.
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
Pertronics conversion John long Engine 14 05-09-2012 07:50 AM
Heater problem turn to engine problem Ridertj Electrical 1 10-29-2011 11:18 AM
timming problem?? or carb problem???? helppp 85 k5 mud truck Engine 9 06-05-2009 01:29 PM
having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC ChevyJim Electrical 5 01-28-2006 07:20 AM
