Pertronix 111 on my 68 gto - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2012, 05:40 PM
Last journal entry: Goat68
I JUST INSTALLED PERTRONIX 111 ON MY 68 GTO,AND NOW I NEED TO SUPPLY A 12 VOLT SOURCE TO THE COIL. cAN I USE THE PINK WIRE COMING FROM IGN 1?
PLEASE ADVISE
THANKS IN ADVANCE
RICH
Old 12-05-2012, 02:19 PM
KMyA
I am not familar with the pink wire from ign 1 so I can't comment on it. Just use a switched 12V wire from the ignition switch.
Old 12-05-2012, 02:47 PM
gearheadslife's Avatar
MentalMuffinMan
follow the old wire back to the bulkhead connector on the firewall(drivers side near brake master) now tap into that wire, it'll be full voltage.. and run a new wire to your distributor..
when you do this and keep the old wire still connected, you by pass the resistor wire.. but you didn't cut it..
tape up the old wire end(at distributor) and if the new set up dies.. you can pop the points back in. untape the old wire and plug in your distrubutor and drive off..
The Following User Says Thank You to gearheadslife For This Useful Post:
GOAT68 (12-06-2012)
Old 12-06-2012, 05:03 PM
Thanks everyone, I will try this and let you know the results
Old 12-06-2012, 05:25 PM
LATECH's Avatar
X 2 What gear headslife said. I like modifications that are reversible like he pointed out.
Fact is stranger than Fiction
Can anyone give me info on a Singer 111 wsv71 NewBee Interior 4 07-12-2010 01:23 PM
Singer 111 Model? Coodeville Interior 3 02-10-2010 09:01 PM
pertronix dakinejb Electrical 3 11-12-2004 09:00 PM
Anyone know much about a John Deere 111 garden tractor? 52Caddy Hotrodders' Lounge 5 06-14-2004 07:16 PM
Pertronix or XR-1 nova69 Engine 3 01-26-2004 08:52 PM
