Pertronix Ignition... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2010, 03:15 PM
Alright first off i will tell you what im workin on. The truck is a 89 f150 2wd used to be a 6 cylinder truck but i took the 6 out and put a carbd 302 in. I installed a pertronix ignition on it. Now since the truck used to be EFI where should i get the 12 volt source for my pertronix ignition. Should i run it off my fuse box?
Old 01-06-2010, 04:00 PM
CQNRQY
12v supply
If you still have the old harness in the truck. I'd use the 12 v ign that was used for the six.es ign.
If not .I'd find a 12v supply that is activated when you turn the key to the ign position. Maybe install a relay that is fed from Battery voltage at the fuse box. That way you wont draw to much from some other circuit : and blow fuses. This is always a good way to isolate an added circuit.
ignition swith problem 302 Z28 Electrical 3 02-01-2009 09:14 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
will pertronix fire stock hei ignition? ted olmsted Electrical 1 08-24-2003 12:01 PM
Installed Pertronix ignition in 68 camaro...need help now. TheZaZ Engine 3 08-08-2002 06:53 PM
