pete jackson gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2006, 09:20 PM
pete jackson gears
Where should the timing marks be on a pete jackson gear setup on a small block 400??
Old 06-13-2006, 01:26 PM
Dot to dot , big drive gear on passenger side,little drive gear on driver side, dot on cam at 6 o'clock dot on crank at 12 o'clock , and that is not to be construed as being #1 TDC firing , because if you rotate crank 360 degrees the cam dot will be at 12 o'clock also and the motor is still in time. Thus this is only cam to crank timing.
Old 06-13-2006, 04:23 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Obviously you must also degree the cam.
Pete Jackson gear drive? chevyelc81 Engine 1 03-31-2008 10:04 PM
Anyone run a Pete jackson noisy gear drive in a sbc? batman09 Engine 60 01-24-2006 01:17 AM
Pete Jackson Gear Drives Canadian Charlie Engine 6 06-10-2005 06:24 PM
pete jackson gear drive 406 ss monte Engine 3 02-05-2004 12:14 AM
Pete Jackson Dual Idler Ger Drive HR Wilson Engine 0 12-23-2002 06:25 AM
