Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pfaff 545 service manual help...
Old 10-30-2010, 08:20 AM
JJ269J's Avatar
JJ269J JJ269J is offline
Thanks Dan. I went through some of the adjustments in the 1245 manual and adjusted the hook and needle timing and it helped. The the hook was passing through the center of the needle to high and skipping a stitch sometimes, especially at higher speeds. Also adjusted the feed dog height because it was rubbing the underside of the needle plate just slightly. It seems to be sewing very smooth now. Thanks again.
