-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Pfaff 545 service manual help... (http://www.hotrodders.com/forum/pfaff-545-service-manual-help-186786.html)
JJ269J 10-29-2010 03:56 PM
I'm looking for service manual for my pfaff 545 to check the timing and overall adjustments because it skips stitches now and again.
I can only find a service manual on pfaff's website for a 1245. Does anyone know if the hook and needle timing measurements are the same, or if I can just go off the 1245 specs? Thanks
DanTwoLakes 10-29-2010 06:12 PM
Yes, you can use the 1245 manual. The 1245 is a new and improved version of the 545. Timing is very basic. The hook needs to go past the scarf in the needle in time to pickup the thread.
JJ269J 10-30-2010 07:20 AM
Thanks Dan. I went through some of the adjustments in the 1245 manual and adjusted the hook and needle timing and it helped. The the hook was passing through the center of the needle to high and skipping a stitch sometimes, especially at higher speeds. Also adjusted the feed dog height because it was rubbing the underside of the needle plate just slightly. It seems to be sewing very smooth now. Thanks again.
suncoastsd 11-03-2010 09:41 AM
Pfaff 545 timing
Keep in mind that there are two needle systems for the 145, 545 and 1245. If the machine is an H3, it will take a 134/35 needle. If it is an H4 machine it will take a 190R needle. The H3 machines have a dual spring bar across the top of the machine. The H4 machines do not.
That could be why the hook was in the middle of the eye. The 190R needle is longer than the 134/35.
The timing is the same, just remember to adjust your stitch length to 0 before timing and adjust it back to sew. This is as critical as the measurements.
Steve M
Tampa
JJ269J 11-03-2010 04:37 PM
The machine is an H4, so your correct that is uses the 190R needles. The 1245 manual worked fine for me, although I don't remember it saying to adjust the stitch length to 0 first. I will have to double check that, but it sews great now. Thanks for the help.
suncoastsd 11-03-2010 04:45 PM
Watch the fore and aft position of the needle as you shorten the stitch length. The needle bar moves towards the back of the machine. My guess is that you need to time the machine in Neutral or the shortest stitch length.
Steve M
suncoastsd 11-03-2010 04:51 PM
There is a timing tool that amounts to a needle bar clamp and a series of feeler gauges. It's been awhile since I have used one, but I believe it is 6.0 mm. We would often use our fingernail and move the needle bar up about the thickness of a Nickel, from the bottom of the stroke.
Steve M
suncoastsd 11-09-2010 07:29 AM
Timing gauge
I ran across the part numbers for the timing tool.
The gauges are 61-111-600-01
The clamp is 61-111-600-35
Here is a link for a parts manual for the 545. It will give you all of the Pfaff part numbers.
http://unlimited.marginspluslive.com...20subclass.pdf
Steve M
JJ269J 11-09-2010 10:33 AM
Thanks! :)
got it covered 09-02-2011 09:38 AM
545 pfaff timming
i have a 545 pfaff too if i timeing it bring the neddle down all the way down on the upstroke the hook has to be 1/16 on top of the needle hole to ajust this their are two screws on the underside of the of the machine on the hook bar you have to loosen so the hook moves freely jerry got it covered
DanTwoLakes 09-02-2011 08:02 PM
Pfaff sewing machines are the best in the business, outside of Adler. Why do I say that? Adler machines have 1/2" main shafts, and all other machines have 3/8" main shafts (both German machines,..... imagine my shock) But,....... any true industrial sewing machine in the hands of a professional upholsterer, and not used at full speed 24 hours a day in an industrial setting, will last forever. These machines were made to sew 3000 stitches a minute 24 hours a
day. The Consew 226- R that I use for almost all my sewing is over 40 years old. The next 5 generations of my family will still be using this machine, and it will perform flawlessly, with only reasonable basic maintenance. There is nothing the average part time, or full time for that matter, upholsterer can do to screw up any industrial sewing machine.
The point is that if you're only sewing one or two interiors, or less than that, you can invest in any good industrial machine and sell it for almost what you paid for it, or make a profit. Maybe not in this economy, but definitely in the long run.
Zenqi 10-22-2013 06:47 PM
Timing a Pfaff 545, Consew 226, Singer 111W and Juki LU-563
Adjust stitch length to zero (no feeding).
Turn handwheel to place needle in lowest position.
When needle is raised 2.5mm above lowest position (in sewing direction), hook point should be directly behind needle.
After setting hook timing, check that there is .1mm clearance between hook and needle.
After setting hook timing, adjust needle bar so that when hook point is directly behind needle, the hook point is 1.6mm above needle eye.
Pfaff545h3 05-12-2014 10:31 PM
Does anyone here know how to replace the needle bar on a pfaff 545. I was told that it is rare that the bar fails. There is nobody in my area that services sewing machines. I just need to be pointed in the right direction. I have all the manuals with the parts brake down.
DanTwoLakes 05-13-2014 07:37 AM
Yes, it's extremely rare a needle bar will break. I had to replace the needle bar on my Consew 226 because I broke the screw off that holds the needle in place.
Before you do anything, mark where the present needle bar is located at each attaching point on your machine. This will give you a good starting point when you install the new one.
Zenqi 05-13-2014 01:21 PM
Replacing needle bar
You will need to slide the needle bar down, so you will need to remove the feed dog and the plate that prevents the needle bar from moving from side to side. You simply loosen the screw that holds the needle bar in place and slide it out. Immediately put the new needle bar in making sure that the bushing that holds the needle bar has not flipped over. Making sure that the timing is set properly, adjust the needle bar so that when the hook point is directly behind the needle, the hook point is 1.6 mm above needle eye.
