Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pfaff 545 service manual help...
Old 05-13-2014, 08:37 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Yes, it's extremely rare a needle bar will break. I had to replace the needle bar on my Consew 226 because I broke the screw off that holds the needle in place.
Before you do anything, mark where the present needle bar is located at each attaching point on your machine. This will give you a good starting point when you install the new one.
