Phenolic gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2008, 07:51 PM
80 SS El Camino
Phenolic gasket?
Hey All,
I'm interested in using a phenolic gasket between my Edlebrock intake and Edlebrock carb. Looking on the summit site I'm not sure which one I need. Is it the 1 hole for the edlebrock or the 4 hole? Just to confirm, Holley and the Edlebrock have the same bolt pattern yes?
BTW the intake and carb are the performer series.
Darrin
Old 10-25-2008, 12:58 AM
327NUT's Avatar
Get the 4 hole spacer, the open spacer is for high rpm race stuff. I'm assuming you're doing this for heat insulation? ........almost forgot, yes, same bolt pattern.
Old 10-25-2008, 08:01 AM
80 SS El Camino
Thanks 327nut,
Yes, it's for heat insulation. The problem is hot starting. I got an 80 Elky with a crate 350. It runs relatively cool, just starting it up after its run for a while is challenging. I'm hoping this will help.
Thanks
Old 10-25-2008, 09:15 AM
Buick Hybrid Guy.
I tend to like the wood spacers that Edelbrock sells. If it's a performer dual plane intake they make a wood spacer that keeps it a dual plane (peice in the middle) I've had problems with the Phnolic one splitting. Wood is the best insulator..
Good luck!
Scott~
Old 10-25-2008, 07:36 PM
80 SS El Camino
Thanks Scott, Ill check out their web site.
Darrin
Old 10-28-2008, 09:36 AM
Buick Hybrid Guy.
Divided 1/2" Spacer, Wood Fiber Laminate #8725*
That's the part number.
PDF with picture... http://www.edelbrock.com/automotive_...tall_items.pdf
Good luck,
Scott~
Old 10-28-2008, 06:13 PM
80 SS El Camino
Perfect, that the one I'll order.
Thanks again
Darrin
Old 06-13-2009, 11:52 AM
GMCTRUCKS's Avatar
How about if he has a high rise manifold would it defeat the purpose of having that type of manifold?
Old 06-13-2009, 01:55 PM
Banned
I'd just run a 1" 4 hole spacer, you can get them for like $10 off ebay. If you're really particular you can fill it in and grind away to make a smooth transition from the carb to the manifold- its worth a few HP. Is it a hot cranking problem though? I tcould be a starter solenoid, that's pretty common.
Altima GXE Intake Manifold Gasket awbazar Engine 5 01-24-2010 07:45 AM
Mr. Gasket Arcuden Engine 12 10-02-2007 04:27 PM
Percy xx carbon exhaust gasket material - passed my first (and second) stress tests lowROLLERchevy Engine 6 02-17-2007 09:29 PM
What will the Mr. Gasket phenolic spacer do to this torque curve? Arns85GT Engine 12 09-22-2005 08:00 AM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
