Phoenix area emission failed twice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2008, 08:48 PM
I recently moved to phoenix. There are only 8-9 emission testing centers through out the city. Sucks!!
Honda Accord 92 with 240K, recently changed distributor cap, plugs and cables (couple of months ago I did ). I moved to phoenix and the initial emission test resulted in FAIL with high CO (12.16 out of 12 ). After doing some research online, I took it for retest with 1 gallon of denatured alcohol (lowes) mixed in a 5 gallons of gas. Before putting alcohol, I took it to dealer for oil change. Before going into test, I drove the car for 15-20 miles on freeway, frequently raising the RPM (by hard pressing accelarator).
Unfortunately, this time it failed again with a new twist. Not only CO was same around 12.4 but also NOX increased. Now my car failed both CO and NOX.
Thanks a lot in advance for your thoughts.
Old 10-18-2008, 08:54 PM
Wiki Edits: 31
get some " gaurenteed to pass " addative.. should work on that car... does it have a cat? 1 of those years Honda ran on the edge of the limit w/o them, and didn't need them.. could be with 240k it's just over the limit.. add in a cat and it might be ok
Old 10-18-2008, 09:08 PM
re: Phoenix area emission failed twice
It might have a CAT, I am not sure. I own this car from 2002 and I never had any issues with it other than regular wear and tear. Neither did I had any emission related nor any engine related issues. I never changed O2 sensor too.
I am kind of hesitant to touch CAt, since it is an expensive repair.
Old 10-19-2008, 12:37 PM
T-bucket23's Avatar
Wiki Edits: 26
The alcohol will raise the NOX. If you retard the timing it will clean up the reading. The higher temps make the exhaust cleaner. This is an old trick that we used to use. I have seen vehicles that were triple the limit pass with near zero reading by setting the timing back to 10 atdc
CHet
Old 10-19-2008, 12:38 PM
T-bucket23's Avatar
Wiki Edits: 26
The alcohol can also damage fuel system parts if they are not designed to be used with alcohol
Old 10-19-2008, 12:54 PM
I immediately diluted it by filling the tank after the test. I hope I wont damage anything.
"I have seen vehicles that were triple the limit pass with near zero reading by setting the timing back to 10 atdc"
How to set this? I am little bit poor in auto repairs. Can it be done by me or do I have to take the mechanic and ask him to set the timing back to 10atdc?
Thank you very much for your inputs
Old 10-19-2008, 03:09 PM
If its free to keep testing, Try getting the engine good and hot. Keep the engine revved to 3K rpm while your waiting in line and see if it passes. Otherwise fork over the money have have a shop tune it.
Jordon
Old 10-19-2008, 03:33 PM
Jmark's Avatar
The phoenix test is pay for the first, get the second free. Third test costs again, then next is free. Kinda sucks but usually, they pass, unless something is very wrong.
12% CO is about choking rich! My old '77 chevy truck usually idles at 3% and runs (45mph) at about 2%.
With 12% CO (was it at idle or "loaded"? ) something is wrong. NOX could also be a bad EGR valve. With that many miles, you may have to take it somewhere to have it checked over good. It may have multiple problems causing the mega high CO and now high NOX.
Mark
Old 10-19-2008, 03:36 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Low CO and high NOX indicate a lean mixture.
Check for an exhaust leak prior to the O'2 sensor. (like the manifold, or, flange gasket)
Replace your fuel filter if you have not replaced it within the last 30K miles.
Also check for a 'loose', or 'worn' timing belt. This can cause the 'intake' cam to be 'retarded' by a few degrees, causing a lack of enough fuel to the air/fuel mixture, leaning it out. The timing belt has a recommended replacement interval of 120K miles.
The O'2 sensor, could be at fault, along with the catalytic converter it's self, but I almost doubt it.
A 'chunk' of carbon stuck in the EGR Valve (holding it open) could also cause this.
Old 10-19-2008, 03:46 PM
redlightning's Avatar
Those cars usually pass.Does it have a miss at about 1800rpm under light acceleration?
If so your egr ports are plugged and need to be cleaned.
And when was the last time it was tested? Was there anything done between the last time and this time? Timing belt?
These cars are speed density.A tight valve could also cause it to go rich.When was the last time they were adjusted?
Old 10-19-2008, 03:49 PM
Jmark's Avatar
CSC.......he failed with High CO.
Also, was this failure showing in "grams per mile" or in "percent"? The IM240 test is "grams per mile" and the older stuff is measured in "percent". Might help to know which one, but i'll suspect that his is GPM, unlike mine as being in %. Actually, all my vehicles are %. My newest one is an '86.
Old 10-19-2008, 04:20 PM
My 2 cents worth
Wiki Edits: 3
Yes, I was wrong, I was thinking CO'2 Percent.
High CO% indicates a 'rich' mixture, and high NOX indicates a "Lean' mixture.
A plugged fuel filter will cause a 'cylinder' miss-fire (too rich) along with an active HO'2 sensor telling the computer to 'lean' me out. The end result would be high NOX, and High CO% readings.
I recommend a fuel pressure test, along with checking for any exhaust leaks prior to the HO'2 sensor.
The timing belt is still in the equation though.
Another thought comes to mind, of an aftermarket 'oil' based air intake system contaminating the 'mass air flow' sensor. This will also cause a 'miss-fire'(high CO% and high NOX)
Old 10-19-2008, 04:27 PM
Thank you very much for your suggestions.
Here are the results from test 1
Gas Cap: Pass
Pressure: Pass
EVAP: Pass
HC : 0.73 gm/mile (standrard: 1):: Pass
CO: 12.16 gm/mil (standard: 12):: "FAIL"
NOX: 1.93 gm/mile (standard: 2.5):: Pass
It was never tested before for emission, coz I was in ST louis and Charlotte, where only safety tests are required for old cars.
Old 10-19-2008, 04:39 PM
Jmark's Avatar
Maybe i'm not reading this right but if the fuel filter is plugged, why would it cause a "too rich" misfire? A plugged filter will starve the engine for fuel, resulting in a lean misfire or complete stall.
A "lean miss" or as I learned it years ago, a "rolling miss" is an acceptable (yea, that's what they said! LOL) amount of misfire due to a very lean mixture at idle.
CO is burned gas.
HC is raw gas.
A lean miss will result in a higher than normal (or acceptable) HC reading as the fuel is not burned and passed right out.
A rich mixture will give a higher than normal (or acceptable) CO reading. IE: way too much gas is being burned in the cylinder.
Old 10-19-2008, 05:11 PM
King of my Man-cave.
A faulty or coated O2 sensor will make the engine run too rich.
tom
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
painting a small area question - help! hutch535 Body - Exterior 5 08-29-2003 07:09 AM
new york area yards? mshellw Hotrodders' Lounge 0 06-14-2003 07:31 AM
las cruces area? dinger Hotrodders' Lounge 1 05-03-2002 07:22 AM
emission testing its_all_good Engine 3 03-01-2002 06:24 PM
