Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - phosphoric acid based rust dissolver
Old 03-07-2005, 08:26 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Phosphoric acid converts the iron oxide (rust) to iron phosphate which is very stable. That coating on the steel is iron phosphate which is a good base for primer. It is working just as the chemists designed it!
