Photos anyone??? #'s before and after - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2008, 11:06 PM
I was wundering if any of you guys had any photos of some Dart iron eagle 200's. I hear some guys talk about fully porting them, some run them as cast, and some just "CLEAN THEM UP". I'm wanting to see the different area's that guys have "CLEANED UP" for better flow, and see what a set looks like fully ported. I may use this info to modify a set for myself, so please be as descriptive as you can in the work that was performed. I probably won't fully port them, but I will gasket match them and do my best to clean them up, but I need to know what area's to really look at to improve the flow and velocity. Where do these things struggle?
Old 10-14-2008, 12:33 PM
automotive breath's Avatar
I ported a set of Dart Iron Eagles with 180cc intake runners a while back.
I'll see If I can find more pictures. The most important area needing attention
is from 1/2" before to 1/2" after the valve, this is the largest restriction
in the port. Learning to size and shape this area correctly is the primary
consideration.
When increasing port size is required, there are several different things you
can do. Gasket matching does almost nothing. Reducing the valve guide
bulge, widening the pushrod pinch, widening the short turn and rising the
roof are a few of the concerns. This is a before and after comparison of
a word products head for a big inch small block.
Old 10-14-2008, 09:41 PM
Not sure I understand
Hey autobreath,
I'm not sure I understand where you mean by "a 1/2" before and a 1/2" after the valve. Are you talking about in the bowl?? If you could find any photos of what that particular head looked like "as cast" and point to or highlight the specific areas I should concentrate on removing material. They won't be going on a really BIG inch small block (355), so I'm not so much concerned with increasing the port size. I just wanna clean them up where ever I can to improve out of the box flow. A 180cc runner would be Ideal for my motor, but according to dynosim a 200cc would do pretty good as well with a little less torque below 4000. However my stall is 33-3500, so I would hope the torque would be there by then.
I looked at the 200's cuz I can get a set new in boxes for 400, and cuz I heard that the 180's flow VERY POORLY as cast.
Has anyone used the dart SS heads. I know they are more of a stock replacement, but I was just wundering how they flow stock and with porting. Are they even worth messing with?? just curious..... I am definitely buying something, I just gotta decide what. I told the guy that runs one of the local engine building shops here in town that I was thinking of gettin a 180cc IE and porting it, and he looked at me like I was an IDIOT and said then why not just buy a 200cc runner. I'm still learning how all this stuff works as far as porting goes, but I would think a head with a 180cc runner thats been ported and polished well would be better then a cast 200cc runner..... Right?? The example I gave him was the flow #'s for a 180cc AFR CNC head v.s. a 200cc Brodix. The AFR is gonna flow better and have better port velocity. He still couldn't understand my logic though. Obviously I'm not gonna get a good of porting job as AFR's in my garage but It still should help.
Old 10-14-2008, 09:59 PM
after the valve...
Take a ruler and measure from the seat ~1/2 into the bowl and measure out
~1/2" into the chamber. Thats the most important area. This includes the valve
job, the bowl and the chamber (shroud). The air must flow freely around the
valve into the chamber with no restrictions.
The size of the bowl is important; ~87% of valve diameter, bigger is not
better. The OD of the shroud in the chamber is determined by the bore.
Put a valve in the guide at Max lift of the cam and take a look at the distance
between the valve and the chamber wall, thats the valve shroud.
Next clean up the push rod pinch and the short turn (bottom of the port where
it turns into the bowl). No need to reshape or resize here, just smooth things
out. Lastly reduce the size of the valve guide boss like in the second picture
above. This combined is generally worth about 0.2 - 0.3 second reduction in
1/4 mile times.
Here's a finished bowl/chamber done by Larry Meaux.
