Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Photos of Main Bearings
Old 12-07-2012, 01:30 PM
MouseFink MouseFink is online now
I rub off the cosmetic tin flash overlay to expose the lead/tin layer. The flash overlay is an electroplated layer of tin on new bearings that only serves as a dry lubricant during assembly. Some bearing manufacturers calls it a "sliding layer" on their tri-metal bearings. Instead of using Scotch Bright, you can also dip the bearings in lacquer thinner and wipe them with a micro-fiber towel.
