Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Photos of Main Bearings
  #29 (permalink)
Old 12-11-2012, 11:23 PM
Big Cliff Big Cliff is offline
Main Bearings
You top coating off the bearings ive seen this in engines with that many miles make sure the crankshaft is smooth when you replace the bearings mic the shaft and use plastic gauge to check your clearance when you install your new bearings.
