Pick the Right Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2010, 05:46 PM
Pick the Right Cam
Ive picked out the right cam for my car but now im worried if i will get that really lopey sound
Lift .510/.510
Duration 244/244
Lobe Centerline 108
ANY THOUGHTS ON CAM SOUND
Old 07-15-2010, 07:33 PM
GMC boogie's Avatar
SBC? That cam will be PLENTY lumpy,so lumpy that you will probably regret it if street driven on a daily basis.
Old 07-15-2010, 08:23 PM
bigdog7373's Avatar
Of course it's fast
wait! is that advertised duration, or duration @ 0.50?
Old 07-15-2010, 09:11 PM
DoubleVision's Avatar
What`s in going in? if it`s going in a 350 sure it`ll lope, that`s a sizeable cam. If it`s going in a 383 it won`t lope as much. A 400 it`ll lope some, 400`s tend to swallow up cams.
Old 07-15-2010, 09:27 PM
its going in a 383
and it 244/244 @50
Old 07-15-2010, 09:34 PM
techinspector1's Avatar
Wiki Edits: 326
Lift .510/.510
Duration 244/244
Lobe Centerline 108
You'll need static compression ratio between 10.5:1 and 12.0:1 to make that cam work. If your SCR is less, expect the motor to be a performance turd that sounds good.
If some of you nutballs would just ask a few questions before you run pell mell into your own ignorance, you might be able to configure a combination that will give both performance and sound.
Old 07-15-2010, 09:53 PM
[QUOTE=techinspector1]You'll need static compression ratio between 10.5:1 and 12.0:1 to make that cam work. If your SCR is less, expect the motor to be a performance turd that sounds good.
383 Stroker
11:5.1 CR
2.02 heads , 1.6 , 64cc
750 carb
3000rpm stall
Old 07-15-2010, 10:22 PM
Wiki Edits: 326
[QUOTE=mr_lwhite]
383 Stroker
11:5.1 CR
750 carb
3000rpm stall
Alrighty then, should work ok, although you'll likely need more stall.
Old 07-15-2010, 10:23 PM
Do you think it will be pretty lopey?
What rpm stall do you suggest?
Old 07-16-2010, 12:21 AM
Wiki Edits: 326
I would expect a "rough" idle. Will probably need 3500 or higher on the converter.
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 01:13 AM
Pick my cam for my blown sbc 350....shooting for 700ish horse darkostoj Engine 11 11-05-2008 01:17 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 09:22 PM
Help Me Pic A Cam? Grant209 Engine 5 12-22-2003 06:05 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 12:29 PM
