Pick your primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2005, 10:02 AM
New Member
Pick your primer
I know that kinds and types of primer are sometimes a prefrence or trial and error type process. But, I was just curious what kind/brand of primer you all prefer to use when you have some body filler in areas and new sheetmetal (ie. bed panels, doors or fenders) on your project. I have been using OMNI 2k2 high build, and its not bad but I would like to try something else next time I prime.
Thanks for your input
Old 07-25-2005, 10:07 AM
302 Z28's Avatar
Depends on what your doing IMO.
The smart thing to do is stick with one particular brand. Example, if your paint is going to be PPG then use PPG primers.
On bare clean and properly prepped metal you want to use a two part epoxy primer followed by a 2K filler/primer.
On fiberglass I use a polyurethane primer first followed by a high build 2 K primer.
Vince
Old 07-25-2005, 11:53 AM
Marhyde makes a good 2k urethane filler primer called ultimate. Cheaper then ppg k200, around $65 a gallon with activator, it thick and has plenty of fill, and sands nicely. They make it in real light grey(tintable), and yellow buff color.
Old 07-25-2005, 10:32 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Southern Poly Urethanes... They make great epoxy and 2k primer for prices you cant beat and the quality is unsurpassed
Old 07-26-2005, 04:45 AM
302 Z28's Avatar
I agree, got to be the best bargain going.
Vince
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
using primer question AdamZx23 Body - Exterior 21 02-16-2005 10:53 AM
Old School - Black Primer Look - Paint Guns primerbaby Body - Exterior 11 02-06-2004 04:59 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 01:28 AM
Sealer reaction with primer? TurboS10 Body - Exterior 10 04-02-2003 04:50 AM
