Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - picking up a new engine today have some simple ?s
Old 02-21-2013, 10:50 AM
oldskool66 oldskool66 is offline
After not being able to track down my masive oil leak and ive given up on that tired 307 im going to be picking up a complete pan to throttle body 96 vortec 350 with about 75k on it from a buddy for 400. i know i need a flywheel and intake for it. but my queston is what cam should i run i just bought a thumper cam from comp because i wanted that rough idle.
my specs for my 79 malibu are as follows
18x10.5 rear wheel with a 265/45/r18 tire
NV3500 5 speed with the 1st:3.49 2nd:2.16 3rd:1.40 4th:1.0 5th:.73
I have a 9" that i will be installing with 3.37 gears that i will be installing
2.5" dual exhaust no cats and 40 series flowmaster
I have 14" wilwood rotors with 4 piston calibers up front and 12"rotors with 4 piston calibers in the rear. i used the factory booster and a aftermarket master cylinder. (can run a vac pump if needed)
i dont drive this car often mostly just to car shows looking for lots of sound dont care about power much
