We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #31
Old 11-21-2007, 02:46 PM
BarryK BarryK is offline
Originally Posted by P.J
At least one more Q, does anyone want to buy about a half a gallon of Picklex20? I hear its some "good stuff."
Disposal is a problem, so best thing you can do is wrap it and give it as an Xmas present to someone you don't like.
Never use lacquer thinner or urethane reducer as a wash before shooting any epoxy or 2K primer, they are not cleaners and because of the ladder scale they are formulated to, they will clean some spots and leave the residue in other spots. It is an easy diagnosis because the question is always the same.
I have spots where the paint is coming off and right next to that spot, you cannot scrap it off with a razor scraper.
Old 11-21-2007, 03:47 PM
crashtech's Avatar
crashtech crashtech is offline
Technician
crashtech's barnstar
Wiki editor
Last wiki edit: How to start hotrodding with little knowledge or money
Wiki Edits: 14
An important point to note is that there are still epoxies out there that are not designed to go to bare metal unless it has been treated with a metal conditioner first! The brand that I and many of the guys here use is specifically designed to go onto bare, sanded, untreated metal, and performs best this way. No matter which epoxy product you use, read the tech sheets very carefully!
Old 09-23-2009, 06:01 PM
46HudsonPU 46HudsonPU is offline
Picklex20 -
http://www.picklex20.com/
According to the manufacturer, it is intended to use as a pre-conditioner - prior to priming, painting, powdercoating, etc.. No rinsing.
I think I would prefer to spray on a coat of epoxy primer on parts, straight out of the media blaster cabinet. From there, they go into dry storage until I'm ready to paint and put the parts on the car...
Old 09-23-2009, 06:59 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Originally Posted by scrimshaw
Why is lacquer thinner not recommended for clean up before epoxy?
The lacquer thinner evaporates far too quickly not allowing enough time to remove all wax & grease, plus it can leave behind it's own contaminates. You are spending big bucks on a paint job, do not shortcut it with inferior products right at the start. A proper wax & grease remover must not be allowed to evaporate, it should be wiped dry with a lint free clean cloth.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "picklex under epoxy"
Dura Glas then epoxy robs ss Body - Exterior 21 11-21-2005 07:18 AM
Marine Epoxy Primer? rlackey Body - Exterior 10 03-24-2005 04:14 AM
Barry, epoxy adhesion testing? baddbob Body - Exterior 21 03-20-2005 09:12 PM
applying epoxy - gun question Dubz Body - Exterior 3 09-15-2004 07:02 PM
Urethane and Epoxy Primers bmech211 Body - Exterior 1 04-17-2004 05:04 AM
