Pickup I-Beam Front Suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2007, 10:00 PM
Looking for ideas on using a '50 Ford F-1 front axle and converting the parallel spring setup over to a transverse spring setup. Ever seen it done? Should I try a Split Wishbone or 4-bar hookup. As a newbie I've looked at tons of photos. I like the "Apperson " style frontends and have seen a few axles with what looks like a flat top spring perch on an old I-Beam axle, but never get a side view to see how the other parts hookup. I have access to machine shop tools and have done some forging and heat treating so I'm not totally intimidated but need advice. Not ready to can the idea yet... Going to try it out for rat rod with custom frame.
Old 01-29-2007, 11:17 PM
aka Duke of URL
It looks like the transverse spring rides on shackle kits and these and the four bar mounts might possibly be located at the current spring perches if you don't want to go to tube.
-SPEEDWAY MOTORS-
Maybe the above will give you some ideas.
Old 01-30-2007, 09:34 AM
If you want to convert the dual spring axle to a transverse spring it is quite simple. Remove the springs and u-bolts from the axle. Cut off or grind the wide section of axle flange where springs rested if you choose to for appearance.
Buy a new Model A front spring and shackles. Fabricate a pair of spring perches which will be welded to the top of the axle duplicating the width and height of Model A spring perches.
Fabricate a pair of batwings to mount your radius rods or four-bar links to and weld to axle at appropriate width for your frame setup. Fabricate or purchase radius rods or four bar links.
66 Mustang front suspension upgrade 66StangBoy Suspension - Brakes - Steering 26 01-02-2007 04:32 AM
Front end for a 47-54 chevy Pickup olsen2544 Suspension - Brakes - Steering 8 08-01-2005 08:46 AM
How Do I "Check" My Front Suspension ? ? white66coupe Suspension - Brakes - Steering 1 09-13-2004 05:45 PM
32 hi boy chrome front suspension McDeuce Suspension - Brakes - Steering 3 12-08-2003 06:52 AM
Brake / Suspension Upgrade - 75 Chevy Pickup dwstevenson Suspension - Brakes - Steering 0 12-31-2002 07:42 AM
