PICS of 1949 Ford F1 with 1991 Jaguar IFS under it -- how would you make this work? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-29-2012, 11:14 PM
jamieson's Avatar
I couldn't take the thought of this whole thread having pictures of just backwards IFS, so here are a couple pics of it flipped.
It isn't in the pictures but I test fit the steering rack and the shaft is placed in a very ideal spot, just inboard of frame rail.
Name:	flipped ifs sideview.jpg
ID:	63528   Click image for larger version
Name:	flipped ifs top view.jpg
  #17 (permalink)
Old 03-01-2012, 05:37 AM
Jag IFS
Don't. Go with MII from TCI.
Jim School of Hot Rod Hard Knocks, 1957
  #18 (permalink)
Old 03-01-2012, 06:09 AM
Are you considering welding in rather than a soft mount? Given the amount of frame modification it may be preferable. I am a strong proponent of installing the Jag in the F-1's in particular, however, I think that the width of the 460 is going to create significant problems unless you mount the engine particularly high for steering and exhaust. My setup is a 383, a stroked SBC which is a fairly narrow engine. I wanted mine centered in the rails to use a mechanical fan which made fitup of steering and exhaust tighter than others that have offset the engine and limited exhaust options. If you were doing an earlier Jag, I would suggest the XJ12 springs given the added weight of the 460. I am unsure if the 12 cylinder engine was fitted into the suspension that you have. I seem to remember that the 12 cylinder stayed with the earlier IFS.
Whatever you decide the best of luck and keep us informed. (God hates a coward!)
  #19 (permalink)
Old 03-01-2012, 06:49 AM
Jag IFS
Jag was the hot lick in early '80s. Then simple to install MII took over. Stick with hugger headers. Thumbs up on the bladed fan, Flexalite stainless flat tip, not pointed, deep pitch, 5 blade.
Jim, School of Hot Rod Hard Knocks, 1957
Name:	our '37 Wild Rod.jpeg
  #20 (permalink)
Old 03-01-2012, 07:16 AM
barrnone50's Avatar
I am doing the jag install on by 51 F-1 using a 86 model. It is real straight forward. Like Willard said fitting that Big Boy 460 could have some issues with clearances. But if there is a will there is a way. I think if you can mock up with front end and motor and steering, which would help you to see if this is the way you want to go. I have seen some that have cut off the trailing arms,I am not a fan of that,but it has been done.If you would like a few pics of my frame and mounting let me know I can shoot some to you.
Good Luck you will make it happen! Happy Trails
  #21 (permalink)
Old 03-05-2012, 12:27 PM
Alberta Bud's Avatar
Alberta Bud
That little rag top is sweet. I don't see a '49 of any type though. Bid ~
How can i make this alternator work? scapegoat Electrical 20 05-29-2010 08:07 AM
Any Ideas on how to make this work well dizzle217900 Hotrodders' Lounge 16 03-08-2010 01:27 PM
can't make it work!!!!!!! peter406 Engine 10 03-09-2009 05:10 AM
will a used t-5 trans out of a 1991 s-10 work with Mustangsaly Transmission - Rearend 3 07-02-2008 08:08 PM
Using Jaguar rims on Ford pszikszai General Rodding Tech 3 05-29-2008 12:25 PM
