Can't tell what make it is but most models of V8's place the alt. to the side and the a/c compressor in the center. The base of you alt. fits in a cradle (bracket alt bracket [--] ). The big casting bolted to the front of the head appears to have such a cradle at the lower left side of the pic. The base mount of your alt in picture fits in the cradle and a long bolt goes thru with a nut/washer combo. The upper/center part of the casting looks to be for the a/c compressor. The upper mount on the alt aprox 2" square with a threaded hole is for belt ajustment and mates with a slotted bracket, sometimes a flat 1/4 x 1.5 strap, sometimes a stamped out bracket. If you don't have one, aftermarket one can usually be made to work. Hope this helps.
THe motor i have bought has everything and is still in car. no guesswork. i have even heard this one run. hope to have it running b4 halloween. take care and thanks.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
