Aftercooler would help make it last longer
Fab up an after cooler for the compressor. I use a coffee can with a coil of copper tube, or aluminum rolled up inside. Attach a small water separating filter down stream and fill the can with ice and water. This will make your desiccant last even longer. Don't forget to insulate the outside of the can. Desiccant dryers work much better when the the inlet air is cooler. Industrial dryers are sized to work with 100F inlet air.
I have an older sand blast pressure pot here..that may be just the perfect thing...Just change some fittings..
Sam
Not sure what those tanks are rated for but, I promise you would still want to change the bungs out to much larger. 1.25" is about right. any smaller and it would take forever to fill/dump. |
testing tanks after welding.
A few years ago I welded a larger bung in an old air bubble. An old welder friend of mine told me how to test it. Stand the tank on end so you can completely fill with water. Then reduce the bung down untill you can screw a grease zert into it. While reducing it down install a tee fitting so an air gauge can be installed so you can check the pressure. Take a hand grease gun and start pumping grease into it while watching the pressure gauge. I pumped my tank up to double what I expect to be the normal air pressure. Water won't compress so if it ruptures all that will happen is you will get wet.
My garage sale find for a tank
A 2.5 gal. pressure paint pot with 2 regs and hose for $5. Heck, a home canning pressure cooker might be usable.
But it can easily be filled with kitty litter and then sealed up, then opened up and dump out old silica (cat Litter; TiDY cat crystals - Walmart carries it). I can drop the whole thing into a larger bucket filled with ICE to cool...I have traps after this...or should I cool the air before it gets to the pressure tank? Its designed for high pressure, plus it has a blead off valve if the pressure gets to high...Only thing to do is to screen off the outlet in side the pot somehow, then maybe put an old tea bag, or coffee filter paper in front of the screen to keep the silica dust out!! BTW this is my first post...I just painted my buddies Hummer plastic fender flare,,, it fell off when the deer ran into the Hummer,,,the deer lost!...I don't know if i can post any pictures yet...
[QUOTE]
So do you fill the whole thing up with desiccant, leaving no air space in the cylinder? I want to do the same this w/e although I plan on buying a 5 gallon air cylinder on Craigslist....
| Recent Garage - Tools posts with photos |
| My air line diagram- where does dryer go | vintagecar | Garage - Tools | 48 | 01-13-2011 11:28 PM |
| Camair dryer | yeepman2 | Body - Exterior | 2 | 09-07-2010 05:35 PM |
| air dryer for air compressor | DadTruck | Garage - Tools | 10 | 05-05-2010 10:33 AM |
| Air dryer | stinger12 | Garage - Tools | 12 | 09-04-2007 10:53 AM |
| Put that headliner in the dryer?? | hotrodf1 | Interior | 10 | 04-16-2007 12:48 PM |
